Go to Post Either this entry is the winner or Andy needs professional help. I can't quite decide which... - Rich Kressly [more]
Unread 02-02-2004, 16:53
tinderfitles tinderfitles is offline
I dont do work on my team!
AKA: Craig o-(-_-Q)
FTC #1180 (Atomsmashers)
Team Role: Leadership
tinderfitles is an unknown quantity at this point
Question need help with the ir
hey does anyone know the angle and distance it will put a robot from the tee if we use the ir system?( sorry if this is on the wrong forum our team is new to posting . any info would help if you have it.
Unread 02-02-2004, 17:20
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: need help with the ir
well, the IR system will probably give you a fairly straight drive towards the IR beacon, so you might look at the angle from the start position to the beacon as your "optimal" angle. the distance from the beacon would probably be a function of your sensor package design.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 02-02-2004, 17:50
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
How are the other teams figuring out the angle form the IR system. I would like to see some example code if possible.
Matthew
Unread 03-02-2004, 15:31
AKA: Craig o-(-_-Q)
ok thank you
