Go to Post You are certainly welcome to demonstrate your geekiness on a regular basis! :) - Cynette [more]
Unread 02-02-2004, 20:38
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
INCONbits.GIEL usage
I have a question about the global low priority interrupt bit. We're using timer3 to sample and integrate a gyro at 100Hz. Since its using the ADC I want to make sure that mainline code doesn't get interrupted in the middle of an ADC conversion.
In the mainline code I think we want to set the GIEL bit low, do a conversion, then set it high again. If the timer interrupt event occurs during the conversion, will the timer3 interrupt bit stay high so that it gets serviced right after resetting the GIEL bit? In the data sheets it looks like the GIEL bit just keeps the low priority vector code from running, but I'm new to the PIC and would like to verify with someone who knows their way around the chip.
Unread 02-02-2004, 23:20
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
FRC #0254 (The Cheesy Poofs)
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: INCONbits.GIEL usage
All interrupts must be cleared in software so I'm pretty sure the answer is yes.
Linux usage of PBASIC djcapelis Programming 2 25-05-2003 23:49
Multiple files usage punarhero Programming 2 12-01-2003 11:45
Whats with the Serout usage? PyroPhin Programming 2 12-01-2003 01:01
material and fastener usage archiver 2000 1 24-06-2002 00:08
Kit Materials Usage & Limitations Rockstar75 Rules/Strategy 1 10-01-2002 17:19
