Go to Post only here would you find someone calling a motor cute.... - Denman [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 02-02-2004, 22:08
Hailfire Hailfire is offline
AKA: Jason
Hailfire has a little shameless behaviour in the past
Send a message via AIM to Hailfire
Network Rendering in 3dsmax
I was wondering how you render your animation by rendering from say, 5 or more computers. I know there's a way of doing it but I don't know how to.
Unread 02-02-2004, 22:45
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Network Rendering in 3dsmax
You can set up a render farm, though you need to purchase additional licenses for that.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 02-02-2004, 23:00
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
I dont think so. The render nodes dont have to have licenses, as long as you use default scanline renderer. Its only the content creation machine that has to have a license. For details on how to set up a render farm - look in 3ds reference and search for network rednering - they have a very good step-by-step guide.
Unread 02-02-2004, 23:32
thoughtful's Avatar
Sorry, i apologize for that i was thinking about Mental ray.
06-Team 1219 Mentor
Unread 05-02-2004, 10:14
rrockafellow rrockafellow is offline
rrockafellow is an unknown quantity at this point
You will install 3ds max on all the machines.
Then you will find that 3ds max has named the Network rendering: Backburner. I can't quote the exact settings/procedure that you'll need to use but you will run all the rendering machines in server mode and one of the machines will run the manager that will connect up to all the slaves in server mode and send them files to render.
The manual/Reference is pretty clear on getting this to work. As long as your computers are networked together and seeing each other it shouldn't be to diiffcult.
Parallel processing for 3dmax mnkysp6353 General Forum 9 06-05-2004 10:26
network rendering bootable CD Nero 3D Animation and Competition 6 16-01-2004 14:41
Adding realism through plugins or alternate rendering engines anishthakkar 3D Animation and Competition 3 10-01-2004 17:26
3dsmax 4.2 | the hardware NaiLZ 3D Animation and Competition 13 11-01-2002 23:44
A (most insane) Network Rendering Crashcourse Robby O 3D Animation and Competition 2 25-09-2001 22:35
