Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 03-02-2004, 10:04
gren737 gren737 is offline
AKA: Sarah Grenier Montplaisir
Rookie Year: 1995
gren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond repute
trying to make a piston in inventor
hey everyone, i'm an engineer and i've been working with inventor for almost a year and a half now and i still have not managed to figure out how to make a piston work properly in an assembly.
i have drawn the piston in 2 parts but i cannot figure out how to assemble them such that the rod will slide inside the tube....i can use the insert offset tool to sort of simlute it, but i want it to slide in and out like the piston would when i move the rest of my assembly.
anyone have any ideas on this?
btw i'm using inventor 8 now.
anybody who has any advice can find me on IM at gren737
thanks in advance
-sarah
Unread 03-02-2004, 10:23
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
Rookie Year: 2000
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Re: trying to make a piston in inventor
By piston i'm assuming you mean piston in a pneumatic cylinder and not a piston in an engine.
Also, I haven't worked with Inventor version 8, but maybe some of these links will help you.
http://www.mymcad.com/iv_tipstricks_answer2011.html
http://www.kacaju.de/docs/ASSEMBLY_M...TH_INVENTO.pdf
Unread 03-02-2004, 11:38
Rookie Year: 1995
yes...air cylinder
and i got it.
i haven't checked out your links yet..but for any of the rest of you trying to do this
use a mate command and grab the axis of each part...not the faces...
-sarah
Unread 03-02-2004, 12:27
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Originally Posted by gren737
yes...air cylinder
and i got it.
-sarah
Another approach would be to make a Tangent constraint between the cylinder and the piston surfaces. Be sure to use the INSIDE tangent. This way you will be able to drag the parts and make them move without having to drive them. The only problem is you won't have collision checking, at least not in 6.0, I can't speak for 8.
It works for me
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 03-02-2004, 15:16
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
any luck using the transitional constraint. i have made some simple stuff but i dont know if that is waht u need.
12 in. Wheel in Inventor 7 petek Inventor 1 17-01-2004 17:53
student inventor matt111 Inventor 7 13-01-2004 17:22
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
