For some reason out of te blue i seem to get this message now when i begin to compile code. How do i get rid of it ? it only seems to happen when i use the laptop, and it neer did it before.
Heres the message: Couldn't locate build tool. Check tool locations. BUILD FAILED: Tue Feb 03 18:42:32 2004 Is it possible it was setup wrong, when it was reloaded ? Thanks. |
Re: Need Mplab help ASAP !!
I would surmise that the build too it's talking about is C18. (Re)install that.
You get that kind of message when the wrong toolsuite is selected in MPLAB. go to Project -> Select Language Toolsuite In the pop-up window is "Microchip C18 Toolsuite" selected as the active Toolsuite? If not select it. If the Toolsuite Contents come up with red X's then you have to click on each of the tools and browse to locate it. MPASM is in C:\Program Files\MPLAB IDE\MCHIP_Tools\mpaswin.exe MPLINK is in C:\mcc18\bin\mplink.exe MPLAB C18 is in C:\mcc18\bin\mcc18.exe Try that and see if you get further. |
| MPLAB error(large pic) | ErichKeane | Programming | 14 | 31-01-2004 16:42 |
| If you're having MPLAB problems, LOOK HERE. | Jeremy_Mc | Programming | 0 | 20-01-2004 18:06 |
| Im am having trouble with the MPLAB | hedgehogger | Programming | 7 | 19-01-2004 17:37 |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 03-11-2003 01:24 |
| Q&A Discuss: FESTO Help ASAP!!!! | CD47-Bot | Extra Discussion | 3 | 16-02-2003 10:55 |
