Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Unread 03-02-2004, 22:23
lasindi lasindi is offline
FRC #1164 (Project Neo)
lasindi is an unknown quantity at this point
IFI Loader Problems
We are having troubles with loading HEX files. When I try to open one that I've compiled, I get an error message that comes up that says, "Run-time error '76': Path not found." I've heard that the directory address of the HEX file cannot exceed a certain number of characters. I moved it to a folder directly on the hard drive and I still get these errors. I'm not sure if the connection has anything to with "path" errors, but we are using a USB-to-serial adapter because the laptop that we're using doesn't have any serial ports. We tried to see if we could open a connection with the robot using a different program and it worked. The loader, however, says that it is "Not Connected". Does anyone know how to solve this?
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
