Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 03-02-2004, 23:51
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
Cannot place constrain in Inventor
So I have a problem in Inventor. I downloaded the van door motor from FIRST CAD Library. And I made a mounting plate for it with 3 screws for the bolts and one hole in the middle for the shaft to go through. I try constrain the two together in a assembely. I first mate the van door motor to the face of the mounting bracket. Then I mate the centerline of one bolt hole to one of the holes in the bracket. Next I try and mate a second bolt hole to the second hole in the bracket except I get an error. What should I do, should I make the holes in the bracket adaptive or what?
-Paul
Unread 03-02-2004, 23:52
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
Re: Cannot place constrain in Inventor
try an insert constraint. Then u can offset however far you need to get the right fit.
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Unread 03-02-2004, 23:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
-Paul
Try making them adaptive only if you're interested in having a nice looking assembly. Do not use the adaptive part as a template for making a real plate.
The bolt pattern of the van door motor model provided in the virtual kit of parts is incorrect. Unfortunately, I don't know what the correct dimensions are offhand, nor can I measure one.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 04-02-2004, 00:03
I know that when designing parts I shouldn't use adaptive things, this is just a general Inventor question. The plate is already made, I just want to model it. I tried the insert command but it didn't work, the problem is that the distance center to center of the holes is not "EXACTLY" the same (at least I think that's the problem). And I got the van door motor from FIRST CAD Library, not the VKOP.
-Paul
Unread 04-02-2004, 00:18
Well I found out a way to do it, sort of. First make the holes adaptive. Then constrain them and take away the adaptivity. This is really wierd and I'm surprised it worked. Does anyone know a better/cleaner way to do it?
-Paul
Unread 04-02-2004, 06:32
Henry Anthony Henry Anthony is offline
FRC #1250 (GATORBOTS)
Henry Anthony is on a distinguished road
Seems like the holes in the motor do not align with the holes in the plate. My recommendation is to start a new assembly. Click Place Component and place the motor. Then click Create Component and click the mating surface on the motor. A new sketch will start after you enter the information in the dialog box. Click Project Geometry and project the holes in the motor to the new sketch for the plate. Continue to build the plate. The holes will line up exactly. A word of caution - if the motor is not accurate as some have written - your plate will match the model but not the real thing. Hope this helps.
Best regards,
Henry
Unread 04-02-2004, 15:07
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
The mounting holes for the Van Door are 1/4" dia on a 1.5" radius. They are 120 degrees apart. I typically have trouble getting it to line up properly. So here's how I handle it.
First use an INSERT constraint on one of the mounting holes on the motor. I usually use the one that sticks out at 90 degrees to the motor axis.
Then I use an angle constraint between the edge of the mounting plate and the web supporting the mounting hole. Adjust the angle as needed to get the holes to match.
The speculation that the problem is not getting the numbers to match is probably correct, but we don't have the ability to specify the numbers to the tolerance needed to eliminate the issue.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 04-02-2004, 15:10
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
so basically you are trying to place 3 holes on 3 pegs?
Unread 04-02-2004, 20:59
The way by creating a component off of the motor sounds like a good idea. Haven't tried it yet but I will. Thanks.
-Paul
Unread 05-02-2004, 05:56
Paul,
The reason it is a good idea is because once you have an existing stock component, like a motor - and hopefully an accurate model - you do not need to analyze the component to create a new sketch for a mounting plate. You just project the geometry and let Inventor do the work. It is a much more productive and intuitive method in my opinion. And you won't get that "Can't create a constraint..." thing anymore. Believe me, I have been there. It drove me crazy. If you need more help, just yell!
Best regards,
Henry
12 in. Wheel in Inventor 7 petek Inventor 1 17-01-2004 17:53
Inventor for Ventures? Jeff Waegelin CD Forum Support 5 03-04-2003 12:33
Help with Inventor Assembling AJ Quick Inventor 4 18-01-2003 09:45
Competition at UTC New England Rick Gibbs Regional Competitions 6 02-04-2002 09:25
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
