Go to Post Consider how nature does this, and emulate. Nature usually has a pretty good algorithm. - DonRotolo [more]
Unread 06-02-2004, 15:34
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Team update #8
http://www2.usfirst.org/2004comp/tmup8.pdf
Update 8 is now out for your enjoyment.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 06-02-2004, 15:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Team update #8
So what happens if a team has already removed their blue wires from the drill motors? We used 8 guage soldered right on there last year and it was fine. If you are careful and good at soldering, you shouldn't have a problem with that.
Besides, that is a really small wire for how much current passes through there at times. Everyone remembers the problems with them desoldering themselves last year.
I'd much rather FIRST made this just an advisory statement rather than a requirement.
Unread 06-02-2004, 15:50
_GP_'s Avatar
_GP_ _GP_ is offline
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
_GP_ will become famous soon enough
Re: Team update #8
Section 5. The Robot
Caution advised regarding the ½” drill motors. You may not replace the blue wires, however, you may shorten them such that there is a minimum of 1.5 inches still attached to the motor and solder heavier gauge wire to their cut ends. Do not attempt to unsolder the blue wires from the brush housings. The plastic brush support housing will distort if exposed to soldering temperatures and the alignment of the brushes will be affected, which can permanently degrade motor performance.
On one of our motors the blue wires fell off and we were forced to solder them back on.... I guess we will have to order a new motor now I wish we had known of this problem earlier
"Victory at all costs, victory in spite of all terror, victory however long and hard the road may be; for without victory, there is no survival" -Churchill
2004 NH Rookie Quarter Finalist
Unread 06-02-2004, 20:29
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: Team update #8
Has anybody ask the question about if you already took the blue wires off the drill motors. If so what do we do. Do we just put them back on and say nothing happen or do we have to buy new ones.
We did not have a problem soldering to the motors in the past or now. We are 4 weeks into it and they change the rules that can't be fixed if already done??????????????????????????????
Building FIRST robots since 1995
BVT Robotics
Unread 06-02-2004, 20:35
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Team update #8
bottle of Testors light Blue enamel paint? One dollar and seventy five cents.
Not having to put the original wires back on? Priceless!
for everything else, theres MasterCard.
Unread 06-02-2004, 22:20
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Re: Team update #8
I wonder if there actually is damage done to the motors when they are unsoldered without any "problems". Someone with a tachometer should see.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 06-02-2004, 22:33
_GP_'s Avatar
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
Re: Team update #8
well when our blue wires fell off one of our motors, we attempted to solder them back on, but in doing so we damaged one of the brushes... the motor works, but I'm still going to order a new one
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
