Go to Post So you wanna be a playa But your gear boxes aint fly? You gotta shift us up To get that high speed drive.... - Michelle Celio [more]
Unread 07-02-2004, 13:06
RiotingNerd RiotingNerd is offline
RiotingNerd is an unknown quantity at this point
Operator Interface code
I'm having some difficulties getting started with the operator interface (my first experience with programming robot was the EDU code).
Question 1:
Is there seperate default code for the operator interface, and if so, where?
Question 2:
Is there a tutorial/documentation on programming the operator interface.
Question 3:
How do you load code onto the Operator interface, because it doesn't have the program button like the robot controller.
Thanks in advance for the reply.
I know I posted in the Control System forum as well, but I'm not really sure where this is supposed to go.
Unread 07-02-2004, 13:08
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Operator Interface code
The answer for all questions is the same. The operator interface is not programmable.
Unread 07-02-2004, 17:04
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
The operator interface is almost a "dumb" device. It simply serves as a means by which to get data between the user and the robot. It also outputs a little data (the led's and the numeric display), but all of that is controlled in the robot code.
Bill
"Those who think that they know everything are especially annoying to those of us who do."
Unread 07-02-2004, 20:51
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
I'm a little confused in this matter, too. In the Competion Port doc, it says something about BASIC and the OI.
Can anyone clarify?
Unread 07-02-2004, 21:00
Mike M. Mike M. is offline
insert custom title here
Mike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant future
look at the date on the guide January 13 2003 it's last years operator interfacecompetition port guide
Gael Force 126 2003-2004 Mechanical, Pit Crew, Grady's #2
T-Hawks 1100 2005-2007 Mechanical, Driver, Coach
Rhodewarriors 121 2007 IRI Operator
PiraTech 2023 2008 Mechanical, Coach
Gael Force 126 2009-2010 Mechanical, Photographer
Current [RIDE] Volunteer Coordinator
Unread 07-02-2004, 21:13
AKA: Jamie Bliss
Thanks, I didn't notice.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
