Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Unread 07-02-2004, 13:43
CPUguy387's Avatar
CPUguy387 CPUguy387 is offline
AKA: Matt
#1189 (Breaking Pointe)
Team Role: Student
CPUguy387 is an unknown quantity at this point
Send a message via ICQ to CPUguy387 Send a message via AIM to CPUguy387 Send a message via Yahoo to CPUguy387
Question Drill Motor Team Update
Hi,
Regarding this statement from the latest team update:
Caution advised regarding the ½” drill motors.
You may not replace the blue wires, however, you may shorten them such that there is
a minimum of 1.5 inches still attached to the motor and solder heavier gauge wire to
their cut ends. Do not attempt to unsolder the blue wires from the brush housings.
The plastic brush support housing will distort if exposed to soldering temperatures
and the alignment of the brushes will be affected, which can permanently degrade
motor performance.
We actually disconnected the blue qires. However, we didn't use a soldering iron, but rather we filed the ends of the brushes to pull out the wires, and now we have 10awg quick-disconnects on there. Do we still need to replace the blue wires?
M@
Unread 07-02-2004, 13:47
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Drill Motor Team Update
That sounds like a question that you should be asking FIRST, you'll get varied answers in the CD forums.
See you in DC!
Unread 07-02-2004, 13:56
CPUguy387's Avatar
AKA: Matt
Team Role: Student
What's the link to their forums again?
M@
Unread 07-02-2004, 14:01
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
They have their question and answer system here: http://www.usfirst.org/robotics/2004/qa.htm
See you in DC!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
