Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 09-02-2004, 00:14
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: how many teams are driving now?
Originally Posted by Alavinus
Team 1123 is/was driving as of Thursday. We then proceded to rip apart the miter gear boxes to make sure they mesh right. After much fine tuning the robot is driving again and we are just waiting on the arm guys to finish their 10.5 ft monster.
By the way... anybody having any suggestions to add 50 lbs. to the robot- we are a little underweight
in 2001 we were insanely underweight (50 lbs total) so we bolted a huge steel plate to the bottom of our bot. I would reccomend doing that or adding something easily removable so when you discover you need another 10 pounds you won't be stuck with a huge blob of metal welded on your frame
Unread 09-02-2004, 00:28
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: how many teams are driving now?
My initial thoughts are to make that arm a big beefy monster! At 10.5 feet... I can imagine that there could be a lot of bending and torque issues. You might as well beef up the arm and use him defensively!
Good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 09-02-2004, 09:57
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
currently, our drive train and electronics and good...the motor/gear/sprocket assembly is finished...it isn't gonna be touched...at all...the electronics for the most part are done and our arm is gettign there. We paln on having driving tests in a week or so...hopefully less but you run with what ya got...that's where we're at...
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 09-02-2004, 11:22
Andyski101's Avatar
Andyski101 Andyski101 is offline
Chegger
AKA: Andy K.
FRC #1143 (Cruzin' Comets)
Andyski101 is an unknown quantity at this point
Send a message via ICQ to Andyski101 Send a message via AIM to Andyski101 Send a message via Yahoo to Andyski101
Unhappy Re: how many teams are driving now?
we were driving last thursday but we flipped ourselves going onto the 6" step . afew repairs and we'er running again. our second robot is still a distant dream.
Andy K.
Unread 09-02-2004, 13:41
ESchneider's Avatar
ESchneider ESchneider is offline
Eric "Schroder" Schneider
#1018 (Pike Robodevils)
Team Role: Student
ESchneider is an unknown quantity at this point
We got something that drives.
Unread 09-02-2004, 14:15
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Team 294 is rolling, but not driving. We even roll straight (imagine that). We do have a warp in the frame, but we are pretty close to square (As seen in image gallery). Hopefully we will be driving by Wednesday.
-Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 09-02-2004, 18:47
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Just got our drive train and out landing gear wired up and running today.
Check out our pics off the whole building process!
http://www.valleytech.k12.ma.us/robo...photos2004.htm
New ones should be added tonight. 2/9/04
Unread 09-02-2004, 23:16
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Rookie Year: 2000
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Team 134 is driving with no problems...just tweaking with ratios...final base
-Pat
Unread 11-02-2004, 14:22
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
we just got one of our two chassis running this past monday. It should be driveable by tonight...hopfully , but we still have two sub-systems to finish as well as mount and wire for our competition bot. Needless to say we still have work to do and it will probably come down to the wire like usual.
Unread 11-02-2004, 14:30
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
we have the motors runnig, but the key stock isnt in yet.
___________________________
If all else fails, use a bigger hammer.
Unread 11-02-2004, 15:39
Levaman's Avatar
Levaman Levaman is offline
A Spy for SIR Intel. Inc.
AKA: A Spy in Plain Site.
#0616 (Southampton Indian Robotics)
Team Role: Scout
Levaman has a little shameless behaviour in the past
Send a message via AIM to Levaman
To all teams that think they are doing good: Team 616 is up and running. By the time the last person leaves to day, we will probably being doing a decent but shaky auton mode.
Everyone thinks they did good to be running and driving early with no subsystems. That's you first mistake. In a few minutes, we will be ahead of everyone in the NASA Langely VCU Regional.
Good Luck. You will all need it.
The Man ontop of the Sites and Works long into the Nights.
Unread 11-02-2004, 20:51
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Ok, not to be rude here, but that's not entirely very GP-ish, and looking at the number of posts you've had, I'm not suprised.
I appreceate your competitiveness, however, you should be cheering on those who have come thus far, escpecially rookies.
Remember, a bot with NO subsystems can still play the game. If a bot simply drives well, It can go far. We even got as far as the eliminations last year after we had to scrap our subsystems for weight.
So, congrats on being a bit ahead, but don't flaunt it here. Instead, congratulate those who have gotten as far as a driving chassis, and try to help those having problems. That's how you're known in FIRST. Not by how well you think your bot can kick everyones butts.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 11-02-2004, 21:25
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
yes! thank you! we wish we were that far ahead... we just finally got half of our wheels on (which means we probably will have more than one wheel eventually) haven't even looked at our electronics yet.
the kind of help we need is probably some one who can draw out a very detailed schedule. and probably someone who can keep everyone from leaving early and work on something useful.
is there a good way to encourage people to come work on the robot on weekends? the only way i've come up with is buy offering free lunch.
and it still doesn't work. i think our team has maybe 10 people, but the only ones working on it are 3?
have to find a way to chain these slackers.
Unread 11-02-2004, 21:53
Sachiel7's Avatar
AKA: Shayne Helms
Sounds familliar
Our first year was exactly the same. We didn't even get ours driving properly, so you guys are probably ahead of us there
Good Job getting as far as you have. If all else fails, get a driving chassis out on that field. It'll do you justice.
Which regional you guys going to?
Anyway, congrats to those who have just gotten something constructed. I've seen teams that haven't even gotten off the drawing board in time.
Great going to all!
-=Sachiel7=-
  #15   Spotlight this post!
Unread 11-02-2004, 22:13
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
We are happy to be dirving on two motors yesterday, did some turn testing in the gym, no trouble there, went to find some carpet. Not as good a story, if you from a dead stop do full forward left and full revese right. It just stalls, (at 150 amps), (get off it quick, havent' blown breakers yet) ordered more sprokets and hope the drill motors, which we just about got on will help. Big issue 2/3s of our mentors and our programmer are off for the whole week end. Still better (I hope) than last year.
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
The Case For 'Regionalizing' teams at the Nationals. archiver 2000 33 23-06-2002 23:35
How do we view more teams? archiver 2000 0 23-06-2002 23:11
Multiple Regionals archiver 1999 55 23-06-2002 22:26
