Go to Post Maybe FIRST made these bumper rules so IRI would have something to blow off come July. - Koko Ed [more]
Unread 07-02-2004, 22:21
Dave... Dave... is offline
#0005 (Robocards)
Dave... will become famous soon enough
TTL pins
The Edubot had three pins for the TTL port and were labeled as Tx, Rx and BLK. The Fullsize RC has 4 pins and are not labeled other than + and B (the + is +5v).
Does anyone have (confirmed) knowledge of what the B and other middle two unlabeled pins are? Has anyone successfully interfaced with the TTL port on the fullsize RC? I've read some other posts and it seems as though some other teams are having trouble with the TTL port as well.
Thanks, Dave...
"...don't worry about that mechanical problem, Dave can fix it in the programming..."
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
dowel pins BBFIRSTCHICK Technical Discussion 10 27-01-2003 11:35
how do you hold pins in? archiver 2001 4 23-06-2002 23:45
drill pins Greg Needel Technical Discussion 2 10-02-2002 19:50
