Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 08-02-2004, 14:31
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Pressure Switch
How are we suppose to wire the cable for the pressure switch to make the compressor turn off. Do we use PWM cables and if so what is the pinout. I am also unsure of how to code the pressure switch in the new controller. Please post your ideas. Thanks
Matthew
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
