Go to Post everyone in FIRST has to do the cha cha slide at least once per season to get it out of their system. Now I can go back to doing it in the privacy of my own car (if you see a red Jeep in CT swerving back and forth don't worry, it's just me doing the slide...)! - KathieK [more]
Unread 02-09-2004, 12:01 PM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Reliable Connections to the fuse blocks.
To all,
The transition block and the 40 amp fuse block are both designed to take #2 guage wire. #6 finely stranded wire (super flex, etc.) allows the strands to ride up inside the threads of the clamp screw. On # 6 and #10 less than the full diameter of the wire can be adequately clamped. This is one solution to a more relaiable and less resistance connection...
For #6 guage terminating into the #2 block:
Start by cutting the wire at least 1/2" longer at the end that will be inserted into the larger block.
Strip 1" of insulation from wire.
Carefully fold back half the length of the exposed wire, forming the end with pliers, into a tight bundle.
Back out the clamp screw on the block and carefully insert the folded wire end into the block, making sure all individual conductors are inserted.
Tighten the clamp screw and test the connection by pulling on the wire.
For #10 guage terminating into the #2 block.
Start by cutting the wire 3/4" longer than needed.
Strip 1"-1.25" of insulation from the wire.
Tin the very end of the wire to hold conductors together. (just the very tip, no more than .125")
Fold two thirds of the exposed length back against the wire end, froming with pliers into a tight bundle.
Fold the tinned, one third back towards the end and form with pliers into a tight bundle.
Both of these methods allow the block to be filled by the conductors and produce a tight connection with fully engaged conductors for the wire guage used.
See pictures attached of our blocks.
ID:	1828  Click image for larger version
ID:	1829  Click image for larger version
Al
WB9UVJ
www.wildstang.org
________________________
Team 1405 looking for a trade of pillow blocks Greg Needel Kit & Additional Hardware 3 02-03-2004 04:44 PM
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 02-13-2003 04:03 PM
Cheap, reliable hosting... Brandon Martus Website Design/Showcase 40 02-06-2003 08:55 AM
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 01-12-2002 07:51 PM
Electrical connections and multimotor mechanisms kmcclary Off-Season Events 2 10-11-2001 02:15 PM
