Go to Post Physics is weird sometimes, this is why we prototype. - Andrew Schreiber [more]
Unread 09-02-2004, 17:18
ahmed ahmed is offline
synOrange
#0843 (White Oaks Wildcats)
ahmed is an unknown quantity at this point
Send a message via AIM to ahmed Send a message via MSN to ahmed Send a message via Yahoo to ahmed
Line tracking sensors - Wiring up?
Can someone provide me with a diagram for wiring up the line tracking sensors or guide me through that?
We had them wired up but the sensors read bogus values.. any help?
Unread 09-02-2004, 17:26
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Line tracking sensors - Wiring up?
Blue - ground
Brown - +12v
Black - signal pin on a digital input
White - signal pin on a digital input
Note: you only need the Black OR the white hooked up since they are mirror values of each other (0 or 1).
Unread 09-02-2004, 20:52
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
FRC #0294 (Beach Cities Robotics)
Rookie Year: 1998
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Banner Sensors Note:
There are two types of Banner sensors
Visible (red LED)
P/N ..VN6. = visible = suitable for line tracking ~4"
IR (can't see)
P/N = IR = suitable for proximity sensing ~15"
Black/White each need the RC's built-in +5v 100K pull up in the digital IO port.
(else you see nothing - unterminated open collector)
else to test w/o IO port connection, connect ~5k-100k ohm resistor
from ea. W & B to +5V and use meter or scope to sense the output.
use Black: (+5v) high = off line, (~0v)Low = on line (same logic as IR rcvr)
use White: (+5v) high = on line, (~0v)Low = off line
There are LEDs on the front of the Banner sensors
that visually indicate the sensed state
that the Black/White communicate to the RC digital input.
Regards, Dale 294
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
line tracking line BerserkerSpyke Rules/Strategy 1 18-01-2003 17:10
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
Goal tracking sensors Carolyn Duncan General Forum 15 24-03-2002 12:40
