Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Unread 09-02-2004, 18:22
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
IFI loader help!
Ok, so i've been trying to download code to the EDUbot for about 2 weeks, but it doesn't work. When I tried to download, a box would pop up saying:
ERROR '6'
Overflow
I would also get back a file called ERROR.MCP, filled with a buncha hex numbers. And the program light would stay yellow. I have IFI_Loader v. 1.0.7 and the memory isn't a problem, the .map file says 41% is used.
I tried copying my code into the default code function by function, and it starts messing up when i get to my absolute value function. For some reason, this works:
short long abs(short long num)
return num;
but this doesn't:
if (num < 0) return -num;
else return num;
Help me please!
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
IFI Loader problems billstu Programming 22 23-03-2004 11:39
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
