Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 09-02-2004, 22:05
actorindp actorindp is offline
actorindp is on a distinguished road
Mapping Buttons to PWMs
Hey guys, how can i map a joystick button to say put pwm08 = 200
Thanks
-Nick
a.k.a
n00b under stress
Unread 09-02-2004, 22:08
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Rookie Year: 2000
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Re: Mapping Buttons to PWMs
In a bit of pseudo code
Code:
if(p1_sw_trig) {
   // When we hold down the button do this
   pwm08 = 200;
else {
   // When we are not holding down the button, do this
   pwm08 = 127;
Unread 09-02-2004, 22:09
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
say you want the trigger to set pwm3 to 200 when pressed, 127 when not:
if(p1_sw_trig) pwm03 = 200;
else pwm03 = 127;
any of the button status variables will work in the if statement.
--edit--
lol, apparently ryan and I are both forum hawks
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 09-02-2004, 22:25
now where do i throw this code?
In default routine?
-Nivk
Unread 09-02-2004, 23:03
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
A good majority of the working modifications you make to the default code will go into user_routine.c, but you will want to throw your autonomous code into a specified area of user_routine_fast.c. There actually is a section of the user_routine.c file that is marked with comments indicating that that is where you need to include custom code. Hope that helps.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 09-02-2004, 23:05
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Another composition of this if-statement would be:
(p1_sw_trig)?pwm03 = 200:pwm03 = 127;
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 10-02-2004, 00:17
Computer Guy
AKA: Dav
or even (if you want to be fancy)
pwm03 = p1_sw_trig ? 200 : 127;
as a general rule of thumb, if you're working from the default code without massive modifications, anything dealing with user control (such as button mapping) will go in Default_Routine().
Unread 10-02-2004, 09:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
If you want to skip the if statement, you can use the following code
pwm03 = 127 + 63 * p1_sw_trig;
If you want your motor to be able to go backwards also, you can use 2 switches with the following code.
pwm03 = 127 + (63 * p1_sw_trig) - (63 * p1_sw_top);
Unread 10-02-2004, 10:59
Computer Guy
AKA: Dav
just a cautionary real-world note, although this may work for the FRC, in actual C, the value of "true" for booleans is not always 1 - in fact, it's often -1.
but yes, for the FRC, one could use Joe's code.
Unread 10-02-2004, 11:11
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Well, to be accurate, the value of true is not-false, that is, anything but 0. But p1_sw_trig is a bit, representing 1 for on, and 0 for off, so it'll be okay.
Oh, and yall don't know how lucky you have it (well, most of you do). Back in my day, we didn't have your stinkin' order of operations, and had to cram our code full of paretheses. (Or, more accurately, casually forget to do so and hit yourself when you see robot go crazy.) Yet another benefit of C over PBASIC. I, for one, am breathing a sight of relief.
Shortcut buttons when posting Wetzel CD Forum Support 2 10-12-2003 15:27
Looking for some help with buttons and pins... Amanda Morrison General Forum 4 26-02-2003 17:32
Assigning Joystick buttons.... archiver 2001 5 24-06-2002 00:59
Where do the stop buttons go??? archiver 2001 0 24-06-2002 00:35
How many buttons??? purplehaze357 Championship Event 0 18-04-2002 23:54
