Re: umm.. heat sinks. sorry, we're roookies.....
We've always been to close to being overweight to worry about it. Question: Whats the best way to cool most motors, like the drill motors we have? Answer: Run them full speed at no load. If you run the drill, you will notice a draft from them. They are designed such that they will such air in and air cool the windings and other hot things. This is then exhasted (the draft) out the back. Cover those, and you will likely overheat and get nice baked motors. Leave them clear and don't worry about heatsinks. Wetzel |
just one more question. do the drill motors suck in air going in reverse too?
you can drill a hole on the bottom of then and mount them with screws....:/
yes, the blower is not directional - it works on centrifical force
it would be good for every team to take a burnt out motor, or one you are not using (like the fisherprice motors) and disassemble it and glue it to a piece of lexan or something so that new students can see whats inside it, and get an intuitive sense of how it works, instead of it being a metal can with two wires coming out. BTW - when you really cook a motor you will know - it has a lingering nasty smell, a little bit like varnish or shellac - and once you cook it the smell never goes away, it will always stink. |
Wow thats a good idea i think ill do that....right..................now.
Im not insain, I'm just...different |
| Heat Sinks for Drill motors | JL Clifford | Motors | 9 | 15-01-2004 18:46 |
| 'IT' info... | archiver | 2001 | 19 | 24-06-2002 01:58 |
| heat sinks | archiver | 2000 | 1 | 23-06-2002 22:45 |
| Heat sinks | Tech Fusion | Off-Season Events | 2 | 11-11-2001 19:57 |
| heat gun | Lake Orion | OCCRA | 2 | 21-10-2001 23:34 |
