Go to Post Omni wheels are cool... but mecanum wheels are COOL!! - dtengineering [more]
Unread 13-02-2002, 23:44
Anne Lam's Avatar
Anne Lam Anne Lam is offline
FRC #0368 (Kika Mana)
Team Role: Leadership
Anne Lam is an unknown quantity at this point
is the reed switch legal?
There appears to be no reed switches included in this years kit. Can this type of switch be used on this years robot?
Unread 14-02-2002, 00:04
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Re: is the reed switch legal?
Additional Hardware List:
. . Switches - any kind/amount
. . Permanent magnets - ditto
There was some talk on FRCtech about this, too, I believe.
Check there for "Official" word.
Unread 14-02-2002, 00:32
Anne Lam's Avatar
Thanks Lloyd. I'll try to look for that post on the message board.
Unread 14-02-2002, 12:39
Rookie Year: 1997
Here is the part of the message pertaining to reed switches: (*+*+*+*+*+* mine)
> If I want to count the teeth on a sprocket with an IR sensor is
> there any approved sensor I can place outside of the custom box to
> do this, if so can it be connected to either the first controller
> or a custom circuit? If not is the gear allowed to enter the custom
> box so an IR device could count the teeth?
A) If it is outside the box, then it must be one of the supplied
sensors.
You may also purchase switches per the Additional Hardware List, such as non-contact reed switches that work with permanent magnets,
and use those anywhere on the robot. Alternately, the gear
may be extended into the custom circuit enclosure in order to be
measured with sensors located inside the box.
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
