Go to Post Free time? You mean the time it takes the code to build? - axiomofdarkness [more]
Unread 10-02-2004, 12:07
Simpson Simpson is offline
Simpson is an unknown quantity at this point
Exclamation Wiring Pneumatics Switch
How does one wire the pneumatics switch to toggle using an electrical imput and not a manual input, like a screwdriver...
Unread 10-02-2004, 12:15
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Rookie Year: 2000
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Re: Wiring Pneumatics Switch
We need more information to answer your question more directly. Here goes some suggestions:
If you are talking about solenoids (You would like to move a cylinder) then you run the wires from the solenoid back to a spike and then pwm cables from the spike back to Robot Controller.
If you are talking about the pressure switch, then you run that to the Digitial I/O pins on the RC.
I would STRONGLY suggest you read the pnuematics guide that FIRST has published and is available on their website.
Unread 10-02-2004, 13:16
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
If your talking manually using a screwdriver you mean a solenoid, most likely the single solenoid (light plastic one). To wire the solenoid your probably got a little sheet of paper that has instruction for putting together and wiring. This all is with the black piece that sticks off the side. Inside is were you connect the wires to like 1 and 2, I think. I'm not sure which one was ground or 12v. Refer to paper if you can find it. Then follow steps alavinus said to wire to rest of system.
Unread 11-02-2004, 12:32
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
however if your like my team, and someone threw out your wiring instructions then http://www.festo.com/INetDomino/file...TValveAssy.pdf has the instructions for the light plastic festo single solenoid.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Beacon selector switch? How to find/make? Fen Programming 13 12-02-2004 16:31
Free Wiring Diagram! Mike Alighieri Electrical 16 30-06-2003 14:31
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
