Go to Post Its not about Poof balls or green lights or getting up on the ramp at the end, this is about the learning experience and inspiration gained throughout the year. - Winged Wonder [more]
Unread 10-02-2004, 17:10
m0rph3us's Avatar
m0rph3us m0rph3us is offline
AKA: Andre
#0293 (Spike)
m0rph3us will become famous soon enough
Send a message via ICQ to m0rph3us Send a message via AIM to m0rph3us Send a message via MSN to m0rph3us Send a message via Yahoo to m0rph3us
Exclamation Harmful side effects with current sensors
While testing the current sensors we discovered potentially harmful side effects on the Controller Interface.
While connecting the speed controller with the motor to measure current we discovered the harmful effect that the sensor has the power to change the analog output on the Controller Interface. When we made the motor go forward the analog output jumped to 10V and when we moved the motor backwards the voltage dropped almost to 0V.
Andre
Team S.P.I.K.E.293
current draw sensors zainali Technical Discussion 2 08-02-2004 11:40
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
