Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 10-02-2004, 18:06
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
Switches...
Hello cool people from this wonderful forum.
I was wondering if there is a way to put switches on the robot like last year.
Remember? that you could set jumpers so the robot will do different things depending on the jumpers.
If there is a way, can you tell me how?
Cause i am writing a dead reck' code, so i wan it to be able to switch the code before the game, you know, like, if i am going to be on the right side, the code makes it go right, an the same with the left.
Thanks.
Oh, one more thing, be happy.
Code\\monkey.
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 10-02-2004, 18:20
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Switches...
just hook them up to a digital input pin, and use and if statement (or multiple if-elses) to select the code to run - you robot can read the input pins any time when it is on, including disabled mode.
you could even wire the switch up to one of the joystick ports on the OI and use that to switch the program - disabled mode allows input from the OI.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 10-02-2004, 19:42
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Re: Switches...
yeah, but i wasn't thinking 'bout a manual switch, where when you want to set it to some state, you just have to press something on the robot. With out touching the OI.
int run = 0;
run = 254;
Unread 10-02-2004, 20:48
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Switches...
yea make a switch box then figure out what the pin numbers are in 1 of your joystick. then wire by wire insert them into the proper pins.....so basically the compition will be over when your done.
Pluss in order to get the arm or whatever you are moving with a switch you need to use encoders so the program knows when to stop the motors.
Unread 10-02-2004, 21:47
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Switches...
Potentiometers. You know the angle (in pot units!)
Unread 10-02-2004, 22:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Switches...
You would have to make sure not to try to read the switch after autonomous mode kicks in, as the OI inputs are not passed through then.
Unread 10-02-2004, 23:04
Computer Guy
AKA: Dav
Re: Switches...
there is that. however, one could simply put the code to read the sensor in Process_Data_From_Local_uP (or Process_Data_From_Master_uP) - thus, once the robot goes into autonomous mode, Process_Data_From_Local_uP is no longer called, and thus the switch value read will not be overwritten.
Unread 11-02-2004, 08:53
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Switches...
Thanks.
Code\\monkey.
Here's an example of something you could do. I only use three switches, but this could be easily expanded.
The firstSwitch and such are the digital pins that the switches you are using are attched to.
User_Autonomous_Code() in fast_user_routines.c
Code:
#define SWITCH_ON 1
#define SWITCH_OFF 0
	unsigned char autonomousSettings = 0;
	// Check switches for settings
	if(firstSwitch == SWITCH_ON)
		autonomousSettings += 1;
	if(secondSwitch == SWITCH_ON)
		autonomousSettings += 2;
	if(thirdSwitch == SWITCH_ON)
		autonomousSettings += 4;
	while(autonomous_mode) // This is the autonomous loop. The switches are evaluated before entering here
		get_data();
		// In here, you can have things that use the settings
		switch(autonomousSettings)
			case 1:  // Right side for autonomous mode 1
				break;
			case 2: // Left side for autonomous mode 1
				break;
			case 3:  // Right side for autonomous mode 2
				break;
			case 4: // Left side for autonomous mode 2
				break;
			case 5: // Right side for autonomous mode 3
				break;
			case 6: // Left side for autonomous mode 3
				break;
			case 7: // Misc empty for now.
				break;
			default: // Use this for error checking
				printf("Something went wrong");
				break; // Force of habit
		put_data();
Well, anyway, I 'm too lazy to type any more. That should give you the idea, though.
Unread 16-02-2004, 12:26
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Re: Switches...
I'm trying to do something similar to what codemonkey is doing. How would I go about making a switchbox for the robot (to attach to the rc)? Basically how do I return a "1" to a digital input.
Unread 16-02-2004, 12:47
Computer Guy
AKA: Dav
Re: Switches...
it's really just a matter of closing the circuit between the GND and SIG pins of the digital input (someone correct me if I'm wrong). just hook up a switch in between the pins.
Unread 16-02-2004, 12:50
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Switches...
use an 8-way rotary switch. This way you can have up to 8 selections and it would be very easy to wire and program
Unread 16-02-2004, 12:54
Re: Switches...
Thanks, that was what I was hoping, the RC guide was unclear to me. Is it legal to use limit switches provided by innovation first in the EDU kit on the robot? We ordered some extra ones. I would have to rewire them because the +5v pin is in the middle of the grounds and sig's and they only have a 2 pin connector
Unread 16-02-2004, 13:13
Programming User
Re: Switches...
Actually, and somebody should correct me if I'm wrong, the pins are pull ups, meaning they are normally on unless something connects the GND and SIG pins, which pushes them off. So, to turn it on, you don't close the GND and SIG pins. Or, I could be totally wrong and you'll have to yell at me.
Unread 16-02-2004, 13:23
Re: Switches...
I'm thinking it returns a "1" if you do close them, there is an indicator LED on the RC, too bad I don't have access to the "robot room" today to test this. I attached a banner sensor once, though, to a digital input and it indicated the switch variable was equal to "1" when the banner sensor detected white, that was of course with the white wire from the banner sensor..... oh well I'll figure out what it does tomorrow lol
Limit switches Team168 Programming 8 10-02-2003 16:22
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
Need help with custom switches archiver 2001 3 24-06-2002 00:35
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
