Go to Post It's your duty in FRC to your teammates and alliance partners to put the most competitive robot possible on the field. - Chris is me [more]
Unread 10-02-2004, 19:29
HWRobotics HWRobotics is offline
HWRobotics is an unknown quantity at this point
Help with window motor
What is the best way to attach a metal disc or an arm directly to a window motor's face? We're trying to use it to power an arm but we want to figure out the best connection without wasting the motor...
-hw robotics team
Unread 10-02-2004, 19:55
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Re: Help with window motor
My team has made couplers for the window motors in previous years. I posted a drawing of one of them in this thread. Put that hole pattern in whatever you want to drive w/ the window motor and you're golden.
-Joel
Unread 10-02-2004, 20:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I think the easiest way would be to use the plastic window motor coupling provided by FIRST. It's a ~4in diameter black plastic disk thing with a coupling on one side for the output gear of the motor and a keyed hole on the other. So you could attach a keyed shaft to the disk or something. Alternatively, you can bolt things to the plastic disk. All in all, highly convenient. If you're missing them, they can be ordered from MMH Ventures.
If you want to be really fancy and you have the equipment, of course, you could just mill out the center of the disk to slide straight onto the gear with some fancy CNC work. I'm guessing you don't have access to this, though, so go with the FIRST provided coupling.
Unread 10-02-2004, 20:03
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
-hw robotics team
Here is an idea I have been kicking around (we will probably use it this year on ours, too).
Take, say, three bolts. Whichever length/size is best for you.
Epoxy their heads to the rotating plate on the window motor (you know, the one with the gear in the middle of it). You could probably do welds, too, but I would be super careful about that. Disassemble the motor before attempting a weld.
drill the appropriate holes in your plate, put it over the bolts, and tighten nuts down.
We are considering this for mounting our stuff on our window motors this year. We considered a straight epoxy, but we wanted to be able to remove the stuff if it gets broken, so we will just do the bolts.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 10-02-2004, 20:11
Rookie Year: 1998
I'd personally worry about epoxy standing up for an entire robot season, but that's just me. Welding would be better, but I think that could be skirting rather close to the no modification ruling. One of the Q&A ruled against modifying the output gear of machining it, so welding seems iffy to me.
Unread 10-02-2004, 20:13
#1067 (SLUH)
Really? I though the gearboxes were always considered fair game . . . ?
Hmm, we are using ours in a very light application, so i think epoxy will be OK for us.
Was the warning about breaking the gearbox or about the legality of it? I thought the rules said the gearboxes were fair game?
Unread 10-02-2004, 20:19
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Only gearboxes that aren't integral to the motor are fair game. The worm gears output stages of window and van door motor may not be modified. <R62>
Unread 10-02-2004, 20:22
Rookie Year: 1998
Answered 1/29/03
Q: <R62> Can we modify or remanufacture the output gear on the window motor? Can we take the output gear off and manufacture a pulley instead?
A: No, you may do neither. Your Kit should contain two couplers you can use to connect the window motors to other items such as pulleys.
Although this seems slightly contradictory to a later Q&A that seems to say you can make modifications to the internals of the gearbox:
Q: Can we add a spacer to the window motor output shaft in order to reduce the play in this part?
A: Yes, as long as you do not electrically modify the motor.
What's even more confusing is that R62 seems really to contradict BOTH answers.
• It is acceptable to modify the mounting brackets and/or other structural parts of the motors (output shaft, housing, etc.) as long as the electrical system is not modified and the integral mechanical system of the moving parts (bearings, bushings, worm gear output stages, etc.) is not changed or removed.
• The gearboxes for the Fisher-Price, Drill, and Globe motors are not considered “integral” and may be separated from the motors. FIRST will not provide replacement for parts that fail due to modification.
Which seems to say that the output shaft/gear CAN be modified, but the internal gear system CAN'T be modified by adding spacers to reduce the backlash. All in all, I'm going to be asking for clarification about this later tonight.
Unread 10-02-2004, 20:27
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
This year we quickly lathed an object with a cylindrical hole that fit over the window motor gear. We then stuck set screws between some of the teeth through the object. Problem solved.
Unread 10-02-2004, 20:46
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Rookie Year: 2000
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Before we can tell you what the best way to do it is we need to know what your machining capabilities are.
Unread 10-02-2004, 21:53
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Stole my idea- 341 did this in the last 'hanging' year, this never failed throughout all of our competitions.. I took apart our old winch a while ago and the window motor in 2000 has a significantly different worm gear, this years gear should still be sufficient... i hate to say this, but even though set screws inhale audibly they work beautifuly in this case
Unread 10-02-2004, 22:39
#1067 (SLUH)
Answered 1/29/03
I don't see the seat motor mentioned. I was operating on the assumption that gearboxes were fair game and was planning on removing its worm gear: it is probably classified as integral, however, so I will need to do something else (although I really don't want the weight entailed by a CIM motor on our arm)
yeah, they prohibit playing with 'worm gear output stages.'
Man, I thought that motor was going to be golden. What if we leave the worm gear on, but modify it so that we can drive our stuff directly from the motor's shaft? Meh, doesn't work under the new "spirit of the rule" thingy. Oh, well. That means we need another victor884 on our control board. Good thing we have 4 + 4 from last year.
Unread 10-02-2004, 22:47
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
we removed the hub and welded a 10tooth #35 sprocket to it and then re attached it It workd Great for our upper arm
Unread 10-02-2004, 23:28
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
We cut a peice of round steel bar. We then machined the pattern internally of the window motor. This creaded a socket that slipped over the output gear.
This was a really high tech custom CNC job that required expertise. I would say that if your team can do it, then do it. Its a real cracker jack output shaft!
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
  #15   Spotlight this post!
Unread 10-02-2004, 23:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
If by "cracker jack" you mean "top quality" then yes it is. They came out really nice and work very well because you can weld right to them. If anyone has any questions about our CNCed couplers, let me know.
window motor spec sheet confusion andy Motors 6 30-01-2004 12:08
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
The window motor is being mean to me... archiver 2001 2 24-06-2002 03:02
window motor archiver 1999 0 23-06-2002 21:52
