Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 10-02-2004, 21:38
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
Drill Transmissions Wobbling???
Tonight we assembled one of our transmissions for the robot. Upon assembly we noticed that the transmissions were wobbling. We took the motors off the transmissions and ran them and they still have a wobble. We could not think of a cause for this problem as we have not done anything to the gearboxes to cause this problem. Has any other team experienced this problem this year or in the past? We would appreciate any help.
Thanks
Unread 10-02-2004, 21:40
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Drill Transmissions Wobbling???
Whe have the same problem. I would like to know the answer tool.
I didn't break it!
Unread 10-02-2004, 21:42
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Just a thought. Try tighting the mounts. the hex cuplings arn't truning "true" so maybe it will work how knows.
________________________________
I didn't break it!
Unread 10-02-2004, 21:57
AKA: Aaron Bradshaw
If we tighten down the mounts it will cause the motor to bind, I wouldnt suggest trying it unless you want to replace your drill motors.
Unread 10-02-2004, 21:58
Crop-Circles's Avatar
Crop-Circles Crop-Circles is offline
The Fifth
AKA: Mike Boehl
#0066 (Flyers)
Crop-Circles has a spectacular aura aboutCrop-Circles has a spectacular aura about
Send a message via AIM to Crop-Circles
Originally Posted by Rhs953
I didn't break it!
Hmmm, I remember hearing that from our drivetrain team an awful lot...
We had a similair problem last year. We blamed many things(the frame, the wheels, Dave, etc.). This year we fixed the problem with one simple equation.
Drill motor=bad
At some point I would like to know what really went wrong, but that's all I know for now.
Rule #1: Fix any and all problems with duct tape and/or zip-ties.
Rule #2: Always respect the authority of the conch.
Rule #3: Goto 20
Rule #4: Don't touch the hair.
Rule #5: (see rule #4)
Rule #6: Never call us the robotics club. We are a team, NOT a club.
Rule #7: The power of the fuzzy compels you.
Rule #8: Show EARL and CHARLIE the respect they deserve.
Rule #9: If it starts glowing, don't touch it.
Rule #10: Gracious Professionalism is a balance. Never leave home without it.
Break any of the above rules and you will be FIRED!
Unread 10-02-2004, 22:00
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
I took a close look at it and it seemd to be the hexagnel cuplink the connects to the drive shaft. It acts as if you would put a drill bit wrong into a drill. It wobbles the sameway. Thus It would seem that the position to the hole is slightly off.
I didn't break it!
Unread 10-02-2004, 22:09
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
will it really? we haven't run our drill motors yet but we have already mounted them. i'm pretty sure we tightened the mounts quite snugly. well, not to the point to where the plastic (mounts from the kit) will crack, but quite tight.
is that bad? how do you know how tight you should crank it
Unread 10-02-2004, 22:12
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
NO don't tighten the motors. It will cause the motors to bind. Then you'll have to buy a new motor for oh about....$70. Just look at my last post.
Unread 10-02-2004, 22:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
The drill tranny is one of the "Great and Terrible" things of FIRST.
They are great because they have a lot of engineering all baked in for you.
They are terrible because they can set a lot of traps if you don't know what you are doing (and even if you DO know what you are doing sometimes).
I really don't like the current drill mounts for 2 reasons. #1 the output shafts cannot take a side load. #2 The drill motors are not really held very well.
We used the drills & drill mounts last year. They were BY FAR our highest failure system on out robot. We are not using them this year.
Joe J.
Unread 10-02-2004, 22:22
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Drill Transmissions Wobbling???
I suggest you take the drill motor out of the transmission and and spin it by hand. Do you feel anything catching? Perhaps the windings on the motor are poor. This happened to us last year, and we simply returned it to FIRST and got another. If one motor is particularly bad.. it might actually be a manufacturing error. If one motor runs significantly poorer than the other.. this might cause you to raise a red flag.
Just a thought.
Good luck everyone!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 10-02-2004, 23:05
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
There is a solution to the problem. If you loosen the pillow blocks this will allow the akles to give a little so you dont ruin the motor. Just a thought.
Unread 10-02-2004, 23:10
AKA: Aaron Bradshaw
We dont have our motors directly driving to the axles. We have them in a two motor transmission that uses the drills and the chips so the pillow block positioning really isnt relevant for us. I know it has to be something in the drill transmission itself as we can take it off of our transmission and the problem still persists with both motors. I dont think it is just one motor that is a "dud" it appears that both of them have the same problem.
Unread 10-02-2004, 23:24
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
then possibly loosen the motor mounts or what ever your axels are mounted on.
Unread 10-02-2004, 23:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We torque all of our drivetrain bolts while the motors are running. This ensures the best alignment of things.
  #15   Spotlight this post!
Unread 10-02-2004, 23:36
AKA: Aaron Bradshaw
I have tested the motors and gearboxes both on and off of our transmissions so it appears that it is either the shaft or the coupler supplied by first that is causing the problems, anyone have any solutions to that problem?
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
