Go to Post Happy Championship and may the odds be ever in your favor! - Jon Stratis [more]
Unread 11-02-2004, 09:50
swabbie58 swabbie58 is offline
swabbie58 is an unknown quantity at this point
Flow rate / remaining pressure
Assume a 6.6CF tank that receives an additional 59.4CF of air every one-second cycle. Within eight cycles the pressure would reach 1022psi and within sixteen cycles 2033psi. The tank is equipped with a safety valve set for 3,000psi. If I begin releasing air after the 16th cycle, how can I calculate the flow rate given that 1) I don't want the pressure to go above that 3,000psi threshold and 2) the tank is constantly being refreshed at that rate of 59.4CF/sec.?
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic equations Ghetto_Child Pneumatics 2 13-01-2002 16:42
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
