Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 11-02-2004, 13:31
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Problems reading io pins as a group
I'm trying to read a group of 4 io pins to get a numerical value as the status of an outboard device. I'm trying it out using the edubot controller so I'm looking at io pins 1-4 which translates to PortA bits 0-3. I was trying to do the following:
sensor_value = (PORTA & 0x0f);
iIt compiles ok, but the result is always 0. I double-checked that I have set the pins to INPUT, and have set the number of analog channels to NO_ANALOG. sensor_value is an unsigned char.
I also tried reading the pins individually as rc_dit_in01 through rc_dig_in04 and got the proper values, so I know the hardware is ok. Anyone know what gives here? Any help would be appreciated.
On another note, I often have problems getting the edubot to take to a program upload. Sometimes it takes 2 or 3 tries before it will run. And it won't hold through a power-down. Do I just have a bad machine? this is true for a fresh load of the Default Code as well as my own, and the same behavior with both versions of the IFI Loader.
TTL pins Dave... Control System 3 07-02-2004 23:59
Joystick problems archiver 2001 3 24-06-2002 02:40
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
Nationals a la NCAA archiver 2000 20 23-06-2002 22:25
