Go to Post PS. Listen to the wise Brandon Martus. Think before you (re)act. - artdutra04 [more]
Unread 11-02-2004, 19:25
gjibben gjibben is offline
gjibben is an unknown quantity at this point
Line-Tracking sensors
Hello:
Have anyone of you been successfull in implemetning the line tracking in the past?
WE need assistance to determine how high from the ground to install our sensors.
We appreciatre your answer
Thank you
Garry Gibbens
Mount Miguel High School
San Diego, CA
Unread 11-02-2004, 21:23
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Line-Tracking sensors
the best way to find out is experimentation - hook a banner up to the edubot or the frc, write some code to echo the input, and watch the output console while playing around with the height.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 11-02-2004, 23:18
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
We have the sensors working this year, they are mounted about 1.5-2 inches from the ground. They have to be adjusted to about all the way toward the plus side to work, but this may also be due to our lighting conditions.
Unread 11-02-2004, 23:48
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Even better, just hook up the power and ground leads of one of the sensors to a 9 volt battery. You don't need to hook it up to a controller to tell when it's seeing it's reflection. It has a little LED on the front of it that will indicate what it's seeing.
Unread 12-02-2004, 11:41
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
This might be a dumb question, but how would you write the line following code using two banners, and how would you place them on the robot.
We have tried to write our own code, but it wouldn't work. (I don't have it on this computer.)
Also do you have to connect one sensor to two inputs, or can it work with just one?
EDIT:
I think the code went something like this:
PHP Code:
if (digi_in01 == 1)
pwm01 130
else
pwm01 124
if (
digi_in02 == 1)
pwm02 130
else
pwm02 124
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 12-02-2004, 11:58
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Each sensor usually needs its own set of inputs, but if you _really_ need an extra input, it is possible to use the analog ones for multiple digital inputs.
Unread 12-02-2004, 12:24
Computer Guy
AKA: Dav
one banner sensor needs one digital input. the banner sensor has two signal wires, but they are always exact mirrors of one another - when one is on, the other is off. just choose the one that is more convenient.
Unread 12-02-2004, 13:56
DART1284 DART1284 is offline
DART1284 is an unknown quantity at this point
Can someone please send me some sample code of how to use them, I am having many troubles.
Thank You
Line tracking sensors - Wiring up? ahmed Electrical 2 09-02-2004 20:52
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
line tracking line BerserkerSpyke Rules/Strategy 1 18-01-2003 17:10
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
Goal tracking sensors Carolyn Duncan General Forum 15 24-03-2002 12:40
