Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Unread 11-02-2004, 22:34
mattf mattf is offline
#0168 (The Flashbacks)
mattf is on a distinguished road
Send a message via AIM to mattf
Re: Yaw Sensor
the yaw rate sensors are analog, and you need to call Get_Analog_Value() on the variable in order to get the actual value. reading it directly won't work (and it looks like that's what you're doing).
also, remember that the analog inputs on the rc are now 10-bit, so without moving the sensor, you should get a reading around 512.
hope that helps.
2004 UCF Quarterfinalists! (168, 79, 710)
2003 UCF Regional Champions! (212, 168, 108)
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
yaw sensor CHSguard72 Electrical 1 06-02-2003 01:44
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
