Yaw Sensor
Can someone tell me how to operate a Yaw Sensor?
Where is it hooked up on the robot controller. Digital or Analog. We did printf's to see what settings were occurring as we rotated it around, but the code only ever showed 135..... Help. Thanks, Phil |
Re: Yaw Sensor
the yaw sensor is an analog device - and you have to supply it with power on its +5V pin - you should see it sitting at 127 or 128 when the bot is not turning, and go up to 254 and down to 0 if you turn the robot fast enough
also, make sure you know the axis of rotation for the sensor - it only senses rotation on one axis. |
Re: Yaw Sensor
Also, the Yaw Rate Sensor supplied for the 2003 season has a higher angular rate capacity than the sensors provided in previous years. The 2003 sensors had a theoretical (according to the datasheet) maximum of 75deg/sec, while previous years' had a theoretical maximum of 64deg/sec. |
Re: Yaw Sensor
But even with the sensor reading 137, when we move the sensor in ANY direction, tilting up/down, or rotating left/right, no change in the 137 value.....
Thanks, Phil |
Re: Yaw Sensor
If you're patient enough, you can take the sensor off the control system and supply it with 5V, connect GND, and use either a multimeter or an oscilloscope to watch the output to see if it changes at all, or even if the normal output is around 2.66V ((5/254)135).
On the other side of things, you can try to determine whether the analog input to the control system is working properly. You can connect a regular potentiometer to the analog input, and see if the read value changes respectively. If that fails, I would check to make sure that the potentometer works properly, etc. Hope this helps. |
Re: Yaw Sensor
Hold the gyro level and twist it quickly 90 degrees or more in the horizontal plane. Code:
// this assumes in User_Initialization() at least...
IO1 = INPUT;
Set_Number_of_Analog_Channels(ONE_ANALOG);
// in Process_Data_From_Master_uP():
unsigned int gyro;
static unsigned long gyroSum=0;
static unsigned int counter=0;
/* This sample assumes a 26.2ms loop */
gyro = Get_Analog_Value(rc_dig_in01);
gyroSum += gyro;
counter++;
if (counter > 40)
gyroSum = gyroSum/counter;
printf(" gyro = %d \n", (int)gyroSum); /* values are in the range 0-1023 */
counter = 0;
gyroSum = 0;
Re: Yaw Sensor
Boy am I new to this stuff. Coding no problem, but a Robot isn't a Database. Thanks, Phil |
Re: Yaw Sensor
Here is the code from team 492's current robot. It uses the ADXRS150 evaluation board. They are available from Future, but I got ours as samples directly from Analog. The basic code works for any gyro, you just need to adjust the various #defines.
Wiring is simple too. The evaluation board is a 20pin dip. You need to connect two pins to ground and two to +5v and one pin is the output. A standard three conductor servo cable is all you need. I put ours on a bit of breadboard + a socket along with some other stuff. Note, our code is called at 100hz. The Gyro has a bandwidth > 40hz so you want to sample it much faster. It wouldn't hurt to sample at 200-400hz, but 100 seems good enough. 38hz (the 26.2ms loop rate for IFI) is too slow. Also note, below, that our observed scale was more like 200deg/sec range vs the specified 150. The scale changes with temperature, so if you want really accurate results you need to use the built in temperature sensor to compensate. I am going to just calibrate at the competition and trust that the temperature will be reasonably constant over the day. Code:
/********************** Gyro Task ***************************************
Gyro output is from .25 to 4.25 volts/5v range. ADC is 10 bits.
Full scale output is +/- 150 deg/sec. Sampling rate is SYSCLOCK hz.
Adjust FULLSCALEINPUT & OUTPUT to match the observed values
so that when the robot is turned 360 deg the reported angle is
360. Double check by returning robot to starting position and
verifying angle is 0.
Note: The gyro reading is 10bits, but I shift it over 4 to get a 16 bit value.
This allows a fractional "offset" value which, when integrated over time
will give a more accurate "zero" value.
#define FULLSCALEINPUT (203.0 * 2.0)
#define FULLSCALEOUTPUT (1023.0 * 16.0)
#define PERIOD (1.0/GYROCLOCK)
#define GYROSCALE (FULLSCALEINPUT * PERIOD / FULLSCALEOUTPUT)
// GyroTask called at the primary loop rate of 100hz. Delay 1.28 seconds before
// setting the basic gyro offset. Gyro seems stable enough to last the 2 minute
// match without drifting significantly. Only high speed turns will mess it up.
#define GYRODELAY 128
int InitGyro = GYRODELAY;
int GyroOffset;
int iGyroTheta, iGyroRate; // These are Zero at boot time
long temp;
float fTheta = GYROSCALE;
void Gyro_Task(void)
int GyroVal = GetADC(Gyro) << 4;
switch(InitGyro)
default: // Delay until stable reading
InitGyro--;
temp += GyroVal;// Get average ADC value over 1 second
break;
case 0:
InitGyro = -1;
GyroOffset = temp / GYRODELAY;
break;
case -1:
iGyroRate = GyroVal - GyroOffset;
fTheta += (float)iGyroRate * GYROSCALE;
iGyroTheta = fTheta; // Make integer version available.
break;
Re: Yaw Sensor
only thing I disagree with on your post is the sensor has a bandwith of 40Hz or so, but your bot is heavy enough that IT wont have a bandwith anywheres near the 26mS sample loop
your motors will not be able to spin the bot around so quick that you need to worry about the bandwidth of the sensor if your bot is jittering and twitching at 38Hz, you've got more problems to worry about than using a gyro :c) |
#10
Get_Analog_Value in an ISR
I want to sample some analog inputs at 4ms.
The first way I tried this was to set up a timer interrupt at 4ms and in the ISR, set a tic4ms flag. Then in the polling loop, whenever the tic4ms flag was set, I'd clear it and run the sampling code. The problem with this is that my main processing, which runs every 26ms, uses about 9ms and I miss some of the 4ms tics. Next try was to read the analog inputs in the ISR itself. I hoped that doing #pragma interruptlow InterruptHandlerLow save=PROD, section(".tmpdata") would save enough context, but it evidently does not - I am getting a smattering of wild data now in the main polling process. First I thought this was because I was calling Get_Analog_Value in the ISR as well as in the main process. Get_Analog_Value uses some SFRs, and they are not saved across the interrupt, so this would be expected to at least give some bad samples if not worse data mangling. But I moved all the analog sampling to the ISR so Get_Analog_Value would be called from only one thread. This did not eliminate the problem. Anybody have suggestions? Also, my assumption is that Get_Analog_Value only runs a few tens of microseconds (15-30 or so) so I can do many of them in a 4ms ISR w/o an overrun problem. This is what it looks like in the pic datasheet. Can anyone confirm this? Thanks for any help. Bill |
#11
Re: Get_Analog_Value in an ISR
Team 492 samples the ADXSR150 at 100hz (10ms). Our basic logic is a 1khz timer that increments a byte counter (atomic operation). In the fast loop of the IFI code we check that counter and do stuff when it increments. The fast loop is called often enough to sample the timer directly (e.g. no interrupts) but we used them anyway in case some code in the Autonomous routines took longer than a milli-second to run. Code:
void Process_Tasks(void)
static char GyroTimer = 0, PrintTimer = 0;
Poll_Rx1(); // The fast loop runs > 100khz
Poll_Tx1(); // Poll rather than interrupts
Poll_Rx2();
Poll_Tx2();
while (MsTimer) // Incremented by TimerInterrupt.
MsTimer--; // Section.
if (++GyroTimer == 10) // 100hz
GyroTimer = 0;
Gyro_Task();
} // END GyroTimer
if (++PrintTimer == 100) // 10hz
SysTimer++; // General timer for system
PrintTimer = 0;
TetherTask(STDIO);
} // END Print task
}// END Tasking
Code:
* FUNCTION NAME: InterruptHandlerLow
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine. Read p. 28 of the "MPLAB(R) C18 C Compiler User's Guide" for
* information on context saving.
* Because this handler calls something, it must save ".tmpdata". If the called
* routine returned a 16 bit variable, "PROD" would need to be saved as well.
#pragma code
#pragma interruptlow InterruptHandlerLow save=section(".tmpdata")/* You may want to save additional symbols. */
void InterruptHandlerLow ()
If (INTCONbits.RBIF) /* INTERRUPTS 3-4 (RB4, RB5, RB6, or RB7) changed. */
DecodeQuadrature(PORTB); // Read PORTB and clear IF to
INTCONbits.RBIF = 0; // clear interrupt
if (PIR1bits.TMR2IF) // timer 2 interrupt?
PIR1bits.TMR2IF = 0; // clear the timer 2 interrupt flag [92]
MsTimer++; // Increment millisecond timer
Last edited by Larry Barello : 25-02-2004 at 11:33. Reason: fixed code formatting. |
#12
Just a heads up... You cant use the gyro from last years kit (very clear... see the QA id's #341, 346, 190). Therefore, you have to use a different one under the custom electronics pricing. The only real viable option is the ADXRS series from Analog Devices, and if you need more then 150 deg/sec, then it will get much harder (the Evaluation Board version of the 300 deg/sec model is just barely over the price limit... you will need to mount 300 deg/sec yourself). Nobody made it very clear in the previous posts, and I didnt know what gyro you were using to begin with.
#13
Your code suffers in a way I was trying to avoid, but may well be insignificant. But here's my issue with it anyway: the "fast" process executes really often, as you say, probably well in excess of 100 kHz, but clearly depending on what you do in it, EXCEPT when data is ready from the master processor. Then the "slow" process is called, and the "fast" process doesn't get called at all while that is happening. In my case that's about 10ms, so I miss a couple of the 4ms interrupts. You code partly deals with this problem, since it counts up 1ms interrupts and later uses them all up, even if more than 10 of them happened without any "slow" process service. So what will happen in your code, if the "slow" process is longer than 10ms, is that sometimes the 10ms code will get called at different than 10ms intervals, causing some jitter in your sampling rate. You'll get the right number of calls, just not at precise intervals. If your slow process does not exceed 10ms, your code is perfect. In my case the desired sample rate was 4ms, and I couldn't get the "slow" code to run that fast, so I miss samples. I should at least switch to your interrupt counting method so as not to miss samples, only have some delayed. Hope this long post was not too incoherent. Thanks for the code snippet. Even though it's not what I wanted, it's an improvement over how I'm doing it and I'll use it if I can't solve the problem another way. Bill |
#14
Re: Yaw Sensor
-Kevin |
#15
Re: Yaw Sensor
| Anyone know where to buy a spare yaw rate sensor? | Jim Meyer | Technical Discussion | 11 | 30-03-2003 21:18 |
| Yaw rate sensor pin-out | GregT | Electrical | 8 | 18-02-2003 00:07 |
| Yaw Rate Sensor to 90 degrees? | Bruce C. | Programming | 4 | 11-02-2003 00:36 |
| yaw sensor | CHSguard72 | Electrical | 1 | 06-02-2003 01:44 |
| Yaw Rate Sensor | ImmacGirl_03 | Technical Discussion | 2 | 10-12-2001 15:15 |
