Go to Post I truly love zipties. They're so elegant - permanent, yet disposable. Strong, yet flexible. Ubiquitous, yet somehow.... special. - Kris Verdeyen [more]
Unread 11-02-2004, 21:40
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
going off the ledge
today we finally got our wheels mounted. (whew, took a while). i tried pushing the robot... basicly a frame with wheels... two of them mounted only temporarily. well anyways, when i pushed it off a 6 inch ledge, it bounced like crazy for a couple feet. really. a couple feet!! in the playing field, we'd be crashing against the fence. and im pretty sure our robot, when it gets to be self propelled, it would be faster than the speed i pushed it off at.
oh yeah, forgot to say, we're using the kit 12 inch pneumatic tires.
for now, our robot isn't even close to 130 lbs. haven't weighed it but guessing its still less than 60lbs. im sure adding weight will help it a bit, but is there any really good ideas how to stop it from bouncing around?
everyone, it would probably be a very good idea to take care that the electronic stuff won't get loose. with speed, thats alot of pounding on your robot.
yeah, and ive considered releasing a bit of air from the tires. but im worried the tire might come off the wheel. is that possible? if it is, is there agood way to make sure it doesn't happen?
Unread 11-02-2004, 21:43
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: going off the ledge
I'd say zip ties....but that just me.
Unread 11-02-2004, 21:48
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I have seen teams partially deflate skyway wheels for better traction (more area rubbing against the carpet) so you could definitely do that.. also, i'd put a weight on the frame to test, max it out at 130, i doubt it would bounce, plus your drivers should have enough common sense not to fly it off the ledge, even though that would be mad cool
Unread 11-02-2004, 21:55
occra 23.
AKA: ryo
None #1481
we probably don't want any more traction for now.....
AHA! testing it with a weight. good idea. how come i didn't think of it before. duh.
and about the common sense? doesn't apply to us... seriously, we are the team who thinks the person who can extend a tape measure out in the air longest without bending is the guy (we don't have any girls on the team..) who has the most skillful hands and the guy who can do a kickflip on a 8by8 piece of wood with 4 castors on it is king.
Unread 11-02-2004, 22:24
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Extending a measuring tape the longest is a very serious deal. During random points during the day, we just have competitions for it. Thats not really that unsual, I think.
You could always limit the power of the motors to make the bot go a little slower, that might help. But adding weight is definatly the first place to go.
Unread 11-02-2004, 22:26
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
This year our electronics sub-team is going to be using the screw in ring-terminals instead of the push-on kind. This i think is going to help in preventing any loose wires on our robot, especially the important ones,
