Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 12-02-2004, 14:56
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
serial
I need a 6 inch serial cable. Any idea where to get one?
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 12-02-2004, 14:58
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: serial
Radio Shack, or basically any electronic/computer supply store should have one.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 12-02-2004, 15:01
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
Re: serial
even one that short?
Unread 12-02-2004, 15:02
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Re: serial
We made some ourselves. They're quite easy to make. You can get the connectors at RadioShack - then just wire the pins.
We actually made a bunch of short (~4 inch) serial cables for all of our robot controller and driver interface connectors. In the past, we've had problems with the constant plugging/unplugging of cables causing the connectors on the IFI controllers to go bad. To solve this, we made a bunch of "pigtail" cables so we leave the pigtail in the IFI connector at all times and then we plug into the pigtail. This eliminates stressing of the IFI connector. We're hoping that this will eliminate our problems.
An ounce of perception is worth a pound of obscure.
Unread 12-02-2004, 15:09
edomus's Avatar
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
Re: serial
We were thinking of doing that also except that the "pigtails" will run all the way to the outside of the bot so that we cause use the tether and program ports without dissasembly.
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
FOR SALE: Long serial cables Cheap!!! sanddrag General Forum 10 06-11-2002 15:39
