Go to Post I guess everyone cant play real defense, like actually pushing the other robot instead of ramming it with the intent to destroy. - Dillon Compton [more]
Unread 12-02-2004, 15:32
Tridelvior Tridelvior is offline
Windbringer
#0348
Tridelvior is an unknown quantity at this point
Question IFI Loader:Unknown Device id (0)
Every time I try to transfer a hex file to the robot, It says "Unknown Device id (0)"
What does that mean?
Team 348 Programmer/Animator/Slacker
Minion #341
Unread 12-02-2004, 16:22
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: IFI Loader:Unknown Device id (0)
I've seen that sometimes when the wrong COM port is selected in IFI_Loader.
Are you using the serial port on your computer or something like a USB-to-serial adaptor?
Try this:
Under "Port Settings" on the IFI_Loader window select each of the available COM ports one at a time and try Downloading over each one.
Unread 12-02-2004, 16:31
Windbringer
#0348
I'm using a USB-Serial cable. Although I've got 10 com ports, I know its in COM 3. I'm trying to find the driver for the USB-Serial in case i need to install it again.
Minion #341
Unread 12-02-2004, 16:38
Just Itinerant
Yea, I had one from Radio Shack that siad it was supposed to be in COM3, and I got the same error you did. I actually found it in COM4 instead.
Ignore what they declare it is and test each port anyway.
Unread 12-02-2004, 16:57
Windbringer
#0348
Thanks again. It works, of course.
Minion #341
IFI Loader usually hangs midway thru load gnormhurst Programming 4 04-02-2004 11:40
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Controllers For 2004 Ian W. Rumor Mill 22 01-10-2003 16:09
