Hi! I got this code from Mr. Kevin's site which is navigate.zip file and i dowload it in the robot and I connect the servo motors to pwm1 and pwm2 and IR sensors to analog I/O but the sensors and servo motor's don't work anyone has any idea why? We are following all the steps there are and our sensor and servo motor's are fine becasue we tried them on edu Rc and they work so they should work on frc as well but they don't?
Re: Navigational problem
this has been mentioned before, but if you are just wanting to test the servos, use tracker.zip, not navigate.zip - navigate is designed to drive the robot to the beacon, whereas tracker simply locks the servos onto the beacon.
| Victor problem | Andy Baker | Electrical | 15 | 24-06-2003 09:49 |
| Ok one problem | cantwell03 | Programming | 3 | 13-02-2003 07:28 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| joystick problem | archiver | 2000 | 12 | 23-06-2002 23:08 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
