Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 12-02-2004, 21:07
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
help! is this bad?
right now, we have for each wheel, on the kit axle. a kit 12in wheel between 2 kit ball bearings on kit pillow blocks. a sprocket is outside one side of one bearing.
like this
B......W........B ........S
E.......H.........E.........P
A===E=====A=====R=====
R.......E .......R.........O
I .......L..........I..........C
NG ................NG.......KET
kinda get the idea? well, you see the sprocket is outside the 2bearings.
do you think we should put another bearing outside the sprocket too?
like this
B......W.........B ..........S..........B
E......H ........E .........P .........E
A===E=====A=====R=====A
R......E .........R .........O.........R
I......L............I ..........C........I
NG ..............NG .........KET......NG
is that 3rd bearing needed? it is too late for us to try to put the sprocket inside the 2 bearings next to the wheel.
we are too close widthwise to make the wheel go onto the otherside of the bearing so the sprocket is between, but the wheel is not.
please tell us what you think. if we should try to put the 3rd one on, or not.
it would help if you could give us some good reasons why or why not too.
please keep in mind that trying to put the 3rd ones on will be very akward on our present design.
thanks!
NYC Regional- Give me the good, bad, or ugly... Rich Wong Regional Competitions 23 28-03-2003 17:56
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
good idea or bad? archiver 2001 4 23-06-2002 23:08
Bad, bad, bad!!! archiver 2000 13 23-06-2002 22:29
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
