4 pin EDU PWM out power, red pin2 V in error
Our EDU controller measures 7.2V(to ~8v charged) on both pins 2 & 4.
Pin 2 (red) should be +5v Pin 4 (unk color) should be 7.2v Has any other teams observed this problem ? I was looking for but find no jumper option (so servo's could use either unreg or reg) We could have a fault/failure inside the EDU +5v power distribution. The middle digital IO pin does properly read +5v (have been using that until problem is resolved) anyone know if there are separate +5 regs inside EDU ? Any ideas what the problem is ? or Do other EDU's have it too ? Beacons w/7.2v to 8V charged, using this fault would start our ~2X brighter 8v-1.34/33ohms=.2A where orig design=5v-1.34/33 =.111A (note IR LED's were tested, forward V=1.34v at .11A dc) |
| PWM port power | rust710 | Electrical | 10 | 21-02-2003 13:56 |
| Ok, so YOU design the 2003 game... | dlavery | General Forum | 157 | 07-01-2003 23:55 |
| Ugh...PWM pin vs. Speed Controller | archiver | 2001 | 1 | 24-06-2002 00:27 |
