Go to Post The less we talk about the game hints the faster they will come. - BrendanB [more]
Unread 13-02-2004, 15:17
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Rookie Year: 2000
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Goaltending?
How do you see the rule on goaltending...
"A ROBOT cannot interfere with a small ball on its downward flight toward a goal or within a goal."
I am a basketball player...and if I am correct this has been taken directly from the rulebook. So as i see it a robot can block a human players shot on the upward flight correct.
Whats your opinion and how do you see the rule?
-Pat
Unread 13-02-2004, 15:26
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Goaltending?
While that may be allowed by the letter of the rules, it isn't within the spirit of the rules. If you were to ask on the FIRST Q/A, you'd probably get a similar response to the person who asked if they could block driver's vision (Absolutely Not!)
Unread 13-02-2004, 15:27
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Goaltending?
You are correct. You are allowed to block balls on their upward flight. However, once a ball starts heading down you are penalized for interferring with it. It is a judges call, so if the ball is going no where near the goal, then you will not be penalized.
See you in DC!
Unread 13-02-2004, 15:28
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: Goaltending?
http://www.chiefdelphi.com/forums/sh...627#post217627
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 13-02-2004, 18:50
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Goaltending?
you would have a tough time blocking a HP shooting, since they are already tossing the ball over the 7 foot wall, and they can step to one side, or step back easily.
If blocking the shooter was your strategy, you still have a week to design and build a new robot. :^)
Unread 13-02-2004, 20:11
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Re: Goaltending?
What is the ruling going to be called if you are trying to score for the other team?????? Lets say you are scoring the 2x ball for the other team to up there score is that goaltending if it stops another ball from going in. Remember is a ball lands on top it is counted to
Unread 13-02-2004, 20:16
Re: Goaltending?
yes they will still call you for goaltending if you are capping the opponents goal while they are still shooting balls at it
how does the ref know if you intend to put the 2X ball on there and leave it there, or if you are only putting it there to block futher shots?
if a ball hits it while you are capping the goal, you are guilty of the crime of goal tending in the first degree.
Unread 13-02-2004, 20:46
nuggetsyl's Avatar
FRC #0025
Team Role: Coach
Re: Goaltending?
I am not blocking your shot though i am scoring. I guess i should go to the first question and answer page to get the right ruling
Unread 13-02-2004, 21:27
nuggetsyl's Avatar
FRC #0025
Team Role: Coach
Re: Goaltending?
After rereading the rules i have got my answer. I was not know that the ball was an extention of the robot. I guess i had a brain fart
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
A Question of Interpretation of goaltending PsiMatt Rules/Strategy 4 05-02-2004 21:36
Goaltending...as a strategy? ngreen Rules/Strategy 14 18-01-2004 06:31
