Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 13-02-2004, 20:24
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Arrgh!
OK. I need a hand here. I'm trying to add a lens effect glow to a robot in our animation but for some insane reason it won't come up in the animation even though it shows up when I render using video post and the settings are similair to a laser effect that was done beforehand. What are we doing wrong?
Unread 13-02-2004, 20:34
Chaz 234's Avatar
Chaz 234 Chaz 234 is offline
#0234 (CyberBlue)
Chaz 234 will become famous soon enough
Send a message via AIM to Chaz 234
Re: Arrgh!
You have to actually render it in Video Post. First put the Add Scene Event thing in. Then put the Image Filter Event in...the glow effect. Then put in an Image Output Event. Make sure they aren't under each other....like indented...err yea.
I'm not great at explaining things...if you don't understand this completely you can go to Help -> Tutorials and search for Video Post. The first part of "Adding a Flare Effect" will help......I think.
Anyway...I hope that helps.
-Chaz-
CyberBlue 234
Unread 13-02-2004, 20:57
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Arrgh!
Thank you.
