Field Tolerances
Forgive me if this has been discussed elsewhere (I searched "tolerance" and did not find this topic) but I just read in the manual (I believe it is section 3.1.1) that field dimensions are + or - 1 inch!
Does this mean that the step has the possiblity of being 7 inches high? They say they will try to get it as close as reasonably possible but a 1 inch difference over 6 inches is a lot. What is the maximum amount higher it is likely to be? Thanks. |
Re: Field Tolerances
The things that vary by up to an inch will be things that very between regionals. For example, the positioning of the middle platform in relation to the rest of the field, and the height of the bar. The height of the steps is fixed once they cut the material, and will be much closer then 1 inch.
| See the playing field in 3D | Glasses | General Forum | 2 | 20-06-2005 20:57 |
| Mobile/immobile objects on field | Steve782 | Rumor Mill | 12 | 08-01-2004 04:15 |
| Could the field be ice? | dez250 | Rumor Mill | 15 | 03-01-2004 18:54 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| Lego field wanted--URGENT!!! | David Kelly | General Forum | 0 | 19-11-2001 12:17 |
