Go to Post step it up, stop trying to validate mediocrity - Aren_Hill [more]
Unread 14-02-2004, 12:02
bludstayne's Avatar
bludstayne bludstayne is offline
bludstayne has a little shameless behaviour in the past
Send a message via AIM to bludstayne Send a message via Yahoo to bludstayne
Square Root
How can I implement a decently fast square root function? Is there any inline assembly I can use?
I hate signatures. I wouldn't even consider having one.
Unread 14-02-2004, 12:48
Paul Paul is offline
lacks sanity
FRC #0316 (LuNaTeCs)
Paul is an unknown quantity at this point
Send a message via AIM to Paul
Re: Square Root
Do you need to take the sqr of the number every loop? If you don't then just find the sqr of the particular number and define it as a constant. If you still need a fast sqr function let me know. Private message me cause I normally forget where I've posted recently lol.
Unread 14-02-2004, 13:15
Mike Bonham Mike Bonham is offline
#0343 (Metal in Motion)
Mike Bonham is on a distinguished road
Re: Square Root
I'm not a programmer, and I'm not sure if this applies to your question or not, but check our Question of the Day ...
http://www.metalinmotion.com
If what you find there is of no help, I'll mention your post to our programming sub-team.
Unread 14-02-2004, 14:48
lacks sanity
Talking Re: Square Root
try this bit of code, it should give you a quick way to find square roots... but only for ints. It is accurate up to a certian point it should have enough accuracy for anything that needs to be done with our robots. If you need anything else let me know.
inline int sroot(int n)
int c = 0; int a = 1;
do {n -= a; a += 2; ++c;}
while (n > 0);
return c;
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
Aspartame shyra1353 Chit-Chat 8 20-01-2004 22:41
Square Rack Sketch archiver 2000 1 24-06-2002 00:09
Notes on building the Square Rack archiver 2000 1 24-06-2002 00:06
Cheaters in the bunch Hey Rumor Mill 23 14-04-2002 11:57
