Go to Post Gracious professionalism... otherwise, the program has failed. - Yan Wang [more]
Unread 14-02-2004, 13:28
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Conditional #define Statements
I'm rewriting the navigate.c class for our team, and I've come to an annoying problem.
I have two sensors, left and right, for each side of the robot. Depending on a switch, only one should be read. That means I can save on code, I think.
With PBASIC, a simple if statement and alias command would set "sensor" to "left_sensor" or "right_sensor" but I have no idea how to do this in C, without going into pointers (which I don't remember).
Is there any way I can make a conditional #define (or similar) statement?
AIM --> Woloi
Email --> ian@woloschin.com
Unread 14-02-2004, 14:59
Paul Paul is offline
lacks sanity
FRC #0316 (LuNaTeCs)
Paul is an unknown quantity at this point
Send a message via AIM to Paul
Re: Conditional #define Statements
Why not just have a conditional declaration?
if(your condition is meet)
int your_var;
else
int something else;
I'm probably misunderstanding you but its still worth a shot.
Unread 14-02-2004, 15:19
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
int your_var;
else
int something else;
Won't work. The declaration goes out of scope after the if block. There are two methods -
1) You know at compile time which one you want
Code:
#if IWANTVAR1
#define myVar var1
#else
#define myVar var2
#endif
//myVar now refers to var1 or var2, depending on IWANTVAR1 (which MUST be either a constant or expand to a constant)
2) You know at runtime
Code:
int myVar;
if(iWantVar1)
myVar = var1;
else
myVar = var2;
Note that way 2 only works for reading the variable, not writing. If you want something like the aliases, you either must know at compile time or deal with pointers (afaik)
I hope this is what you wanted...
Unread 14-02-2004, 18:14
College? What?
Ah, thanks, I didn't think about doing something simple like just reassigning the variable to a temporary variable. Seeing as I only need to read, I think I can make do with that, but I'll have to fool around with it a bit.
On the other hand, it's always a good time to relearn pointers...
AIM --> Woloi
Contradictory FIRST Statements Gobiner Rules/Strategy 10 14-01-2003 16:12
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
Logical statements or math formulas Manoel Programming 1 16-02-2002 23:29
