Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
Unread 14-02-2004, 14:01
bludstayne's Avatar
bludstayne bludstayne is offline
bludstayne has a little shameless behaviour in the past
Send a message via AIM to bludstayne Send a message via Yahoo to bludstayne
Square Root Function not working
Why isn't this working? I always get a value that's too high. 4 would give me the correct value, but 9 up always goes over. It's kind of weird too, every perfect square makes it go over a little less, you can check it out and see what I mean.
Code:
float sqrt(unsigned int tar, float accr)
    float i;
    for (i=0.0f;i<tar;i+=accr)
        if (i*i >= tar)
            return i;
I hate signatures. I wouldn't even consider having one.
Unread 14-02-2004, 14:52
Paul Paul is offline
lacks sanity
FRC #0316 (LuNaTeCs)
Paul is an unknown quantity at this point
Send a message via AIM to Paul
Cool Re: Square Root Function not working
http://www.chiefdelphi.com/forums/sh...618#post221618
I responded to your origonal post. See if it helps you out any.
Unread 14-02-2004, 22:33
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This code is based on an algorithm I found on Microchip's web site. Its for 32 bit integers, but can be adapted for 24 and 16 bit ints by changing the mask and result values.
Code:
typedef unsigned long uint32;
uint32 sqrt32(uint32 x)
	uint32 mask = 0x1000;
	uint32 result = 0x800;
	while (mask > 0)
		if ((result * result) > x)
			result &= (~mask);
		mask >>= 1;
		result |= mask;
	return result;
Unread 15-02-2004, 08:50
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Do you really need a sqare root? We originally had a square root in our waypoint calculation (to determine the distance from us to the waypoint), but we determined the square root was unessecary. Why? Because we're using feedback control to get to the position AND x^2 + y^2 becomes zero at the same point as sqrt(x^2 + y^2). Anyway, it's just a thought - you may not need the square root afterall.
-Chris
An ounce of perception is worth a pound of obscure.
Unread 15-02-2004, 09:17
Rookie Year: 1997
Code:
    float i;
        if (i*i >= tar)
            return i;
Now, to answer your original question:
It is always high due to the >= that you have in the 'if' statement. It won't return a value until it becomes equal or GREATER THAN your value. The odds of it being equal are quite low. Therefore, you're always going to get something that is higher. In fact, it is IMPOSSIBLE to get a value that is lower than the actual square root.
I see two ways to increase your accuracy (I could probably come up with more, but I just woke up).
The first is to make 'accr' smaller. This will give you more accuracy. However, this will also result in slower code.
Here is another way the should give you decent accuracy without much more computation: linearly interpolate between the two points surrounding the square root. Here is an example:
Code:
    float i;
    float i_prev;
        if (i*i >= tar)
            break;
        i_prev = i;
    // return a linearly interpolated value
    return (tar*tar - i_prev*i_prev)/(i*i - i_prev*i_prev) *
             (i - i_prev) + i_prev;
If you don't want to get that complicated, just average the two values surrounding your target:
Code:
    float i;
    float i_prev;
        if (i*i >= tar)
            break;
        i_prev = i;
    // return the average of the point before and the point after the sqrt
    return (i + i_prev)/2;
Unread 15-02-2004, 09:41
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Code:
    float i;
        if (i*i >= tar)
            return i;
Why this goes over has already been answered, but I should also point out that this algorithm will be incredibly slow, and not particularly accurate. Two things:
First off, it is a cardinal sin to have a floating point value as a loop index. The problem is that floating point numbers always have some round off error. And, each time you add, the round off error increases. So, for example, if tar = 1, and accr = 0.1, after 10 iterations, you may get i = 0.9999999 or you may get i = 1.0000001. If you get the former, you'll end up with the square of 1 = 1.1 b/c you'll go one step too far. If you get the later, you'll get the right answer. But there is no way to know which you'll get ahead of time.
The problem of floating point loop indexes can cause such subtle bugs that some languages do not allow it at all (e.g. recent versions of FORTRAN). The following is the recommended replacement:
Code:
    int i;
    float j;
    j = 0;
    for (i=0;j<tar;i++)
        j = i * accr;
        if (j*j >= tar)
            return j;
    return -1; //signal an error.  should never happen, but it is bad form to
                  //simply not return any value.
Secondly: the algorithm itself converges slowly. E.g. if you try to take the square root of, say, 100 with accr = 0.1, it will take a LONG time (1000 iterations) to get a correct answer. Try a different method. The most common method to numerically compute square roots is called Newton's method. Do a search on google for "Newton's method square root" and you should find some good example code. Newton's method will converge to a reasonable value after only a few iterations.
/* Daniel */
Unread 15-02-2004, 11:23
lacks sanity
Talking Re: Square Root Function not working
Code:
    int i;
    float j;
    j = 0;
    for (i=0;j<tar;i++)
        j = i * accr;
        if (j*j >= tar)
            return j;
I've used Newton's system of finding square roots, and it is pretty fast. Take a look at this code, it only works for ints but it should be good enough for what you need. It takes a a number of interations equal to the square root. For instance, to get the sqr of 16 it would take 4 interations, 100 would be 10 and so on and so forth. See how you like it.
inline int sroot(int n)
int c = 0; int a = 1;
do {n -= a; a += 2; ++c;}
while (n > 0);
return c;
Unread 15-02-2004, 12:09
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
-Chris
If you do find you need to compute sqrt(x^2+y^2), might I suggest the CORDIC algorithm (mentioned here before for sin/cos by Kevin Watson, I believe ... I found it very useful). Here is a very good file explaining it: http://www.andraka.com/files/crdcsrvy.pdf. The nice thing about it, is that it is a "shift and add" algorithm ... which is very fast. Maybe I'm just wierd, but I thought it was cool, and was disappointed when I realized we wouldn't be using it ... like Chris said he didn't need to compute the sqrt, we figured that we might not need to compute trig functions ourselves either.
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
Square Root bludstayne Programming 3 14-02-2004 14:48
Aspartame shyra1353 Chit-Chat 8 20-01-2004 22:41
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
