Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 14-02-2004, 14:39
tophq's Avatar
tophq tophq is offline
mastr of autodsk (or not)
AKA: Chris Payk
#0703 (Inferno)
tophq is an unknown quantity at this point
C Programming Question
Ok, before I begin let me start off by saying that I have checked around to find the answer ot my question and I have not found a suitable answer, this may be due to the lack of my attention span though...lol. Ok my problem is I'm trying to use the trim wheel on the joystick to set the robot into autonomous mode. Now I first added the
Code:
unsigned char wheel_right
to the user_routines.h header file and I still keep getting errors. It says "wheel_right is not defined" when I try to build it. I also tried adding the code directly before the function but when I do that it says I have multiple definitions and it still won't build. Where and how do I need to define and declare my variables. Any help would be greatly appreciated.
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
A question about control system options computhief263 Control System 7 04-02-2004 14:46
Q&A Discuss: Quick C Programming Q CD47-Bot Extra Discussion 6 16-11-2003 11:16
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
Programming question archiver 2001 6 23-06-2002 22:57
