Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 14-02-2004, 15:37
great_one411 great_one411 is offline
#1210 (NYACK)
great_one411 is an unknown quantity at this point
Question Modifying Default code
How do you modify the Default Code from one joystick to two joysticks
Unread 14-02-2004, 15:55
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Modifying Default code
[edit] Forgot the rest of the story. This goes in Default_Routine() in the user_routines.c file. Comment out the 1-Joystick lines:
Code:
//pwm13 = pwm14 = Limit_Mix(2000...
//pwm15 = pwm16 = Limit_Mix(2000...
and add in
Code:
/*------------ 2 Joystick -----------------*/
pwm13 = pwm15 = p1_y;
pwm14 = pwm16 = 254 - p2_y; // Assumes your motors are reversed, just p2_y if not
Unread 15-02-2004, 08:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Basically what he said, just simplified. To map two joysticks, you would do something like this:
Code:
// This code assumes the joystick are on ports 1 and 2 and pwm01 and 02 are the drive motors.
// These can be easily changed
pwm01 = p1_y;
pwm02 = p2_y;
That code just makes the Y axis of the joysticks on ports 1 and 2 run the left and right drive motors.
Unread 15-02-2004, 09:44
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The default code already has two joystick drive on pwm01 and pwm02. You just need to change pwms. No code changes necessary.
Unread 15-02-2004, 12:44
Just Itinerant
Depends on which copy of the default code you're working with.
IFI dropped the 2-joystick code from later versions.
Unread 15-02-2004, 13:00
Rookie Year: 1997
I know it was in the first version posted, and its also in the current version (2-10-2004). I haven't used any intermediate versions, but I find it hard to beleive that Innovation FIRST would have dropped it.
Lines 211 and 212 (in Default_Routine)
Code:
  pwm01 = p1_y;
  pwm02 = p2_y;
Unread 15-02-2004, 13:02
Programming User
I just thought the example without all the extra stuff would be helpful.
Unread 16-02-2004, 10:32
Just Itinerant
Code:
 pwm01 = p1_y;
pwm02 = p2_y;
I looked right past the obvious!
I believe at one time (maybe EDU code) they had the line:
Code:
/*---------- 2 Joystick Drive ----------------------------------------------
and that's what I was missing.
Thanks!
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
