Go to Post The easiest and most effective way to do this for the Championship event is pre-competition scouting, with statistics. Nothing beats it. Hands down. Period. The End. Nothing's better. - Tom Bottiglieri [more]
Unread 14-02-2004, 15:44
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Interrupt Handlers and Variable Scope
I'm trying to implement a shaft encoder which simply triggers an interrupt handler and increments a variable every time the encoder creates a pulse.
The code mostly works, in that the interrupt handler is called when the pulse on Digital Input 1 occurs, it then checks the value of digital input 10 for the B phase, and increments and decrements a counter as appropriate.
The interrupt handler is getting called, since I can put debugging printf()'s in there which show +'s and -'s every time the handler is called.
The problem is that the global variable I'm using isn't ever incremented or decremented, like a scope problem.
I've read the C18 manual about interrupt handlers, and thought I had everything taken care of:
I've already got a
#pragma interruptlow interrupt_handler_low save=section(".tmpdata)
And I've tried
#pragma interruptlow interrupt_handler_low save=variablename
but neither of these help. Ideas?
(I'd post the exact code, but it's over with the bot without an internet connection. Perhaps later this evening).
Unread 14-02-2004, 16:52
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Interrupt Handlers and Variable Scope
Put the keyword "volatile" in front of your global variable declaration. I put a description of what this does in this thread.
Unread 14-02-2004, 18:30
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
I've already got a
And I've tried
There is example code here that does exactly what you want. You'll just need to drop encoder.c/.h into your build and modify your user_routines_fast.c file so that the proper interrupt handlers are called.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
