Go to Post We're not disappointed if we don't achieve excellence, so long as we did everything we could in our pursuit of it. - JVN [more]
Unread 14-02-2004, 19:40
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Boolean statement
simple question, in an if statement is a value of 0 = to false or to i need to say !variable==0 to get false( or variable==1). not too important it will just save me time in writing the code and i dont want to go back and have to fix it.
Unread 14-02-2004, 20:00
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Re: Boolean statement
int x = 0;
if (x)
//this code never executes
else
//this code always excutes
However, in C, I would consider it to be good coding practice to explicitly write the test as:
if (x == 0)
// stuff
else
// other stuff
or even
if (x != 0)
//other stuff
else
//stuff.
/* Daniel */
Unread 15-02-2004, 07:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Just to clarify what he said, in C any non-zero value is true. Zero is false. So, if you had a variable and you wanted to test if it was zero, you could say:
Code:
    if(!variableBeingTested)
    	// Variable is zero
    else
    	// Variable is not zero
It is considered better form by most people, however to explicitly put in the test for zero. For example:
Code:
     if(variableBeingTested == 0)
     	// Variable is zero
     else
--EDIT--
PS I just looked at the last post guy's name and team number and realized he's one of my team's mentors.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Mission Statement Madison FIRST-related Organizations 11 19-05-2003 14:54
Help w/ a Research Paper concerning a Dean Kamen statement Ryan Dognaux Chit-Chat 1 10-02-2003 22:55
Varying levels of enforcement... Gui Cavalcanti General Forum 9 28-03-2002 16:29
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
