Go to Post Don't you have some rovers to redirect or something Dave? - Rich Kressly [more]
Unread 15-02-2004, 01:29
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Number/Type of Motors
If we are given 2 Van Door Motors and 2 servo(motors0 in the Kit, Can we use 1 Van door and 3 servos?
I understand that Update#9 states "We will allow you to use more than 2 hitec servos on your robot. They will still be treated as Motors, however, with regards to modifications."
Does this mean that we could run 5,6, or 7 servos if we need to?
We are looking at using 2 servos for the IR Sensor sweeping, and show a need for additional servos for other (undisclosed) purposes on the robot.
Thanks,
Phil
(I can't post to the Q&A section of the FIRST site.)
Unread 15-02-2004, 01:32
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Number/Type of Motors
You can't use more then the quantity of *each* type of motor in the kit, with the exception of servos. Thus, if you could use 10 servos if you wanted, but only a maximum of 1 van door motor (since that is how many got in the kit). It doesn't matter if you use less of one motor, you still can't use more of another.
Unread 15-02-2004, 01:56
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Great.
We are only using 5 of the existing kit 'o parts (I mixed up the type) but are planning on using several Servos (3-6).
Next question, Are we also stuck to only HS311 or HS322, or can we use other servos models ie. HS81 (smaller/lighter/same voltage etc.)
Thanks again,
Phil
Unread 15-02-2004, 01:57
Rookie Year: 1997
Only those two models.
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
