Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 15-02-2004, 18:40
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 350 arm
Unread 15-02-2004, 18:41
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: pic: 350 arm
it looks heavy; are those sprocket steel?
And wood, heavier that aluminum for the same strength, am I safe in assuming this is a prototype?
Looks strong though, Probably looks really cool in action.
Edit: is that a window motor driving a kit gearbox I see? Clever!
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 15-02-2004, 19:44
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Re: pic: 350 arm
yes it is heavy, this pic was taken before we started drilling weight reducing holes
yes it's a steel sprocket
no it is not a protoype, we don't have enough money/ time to build it from metal
yes it is strong
and yes it is a window motor driving a kit gearbox. The gear ratio on the second stage part of the arm is 1:16. That window motor will lift the second stage no problem.
due to weight we decided to take out one of the sprockets
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
pic: The long arm of the law. CD47-Bot Robot Showcase 12 16-02-2004 22:43
pic: Team 930 telescoping arm CD47-Bot Robot Showcase 1 13-02-2004 16:24
pic: 350 prototype CD47-Bot Robot Showcase 10 05-02-2004 13:23
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
