Go to Post Note to self: Go to IRI sometime. - [more]
Unread 15-02-2004, 22:22
Nuson Nuson is offline
Nuson is an unknown quantity at this point
motor performace white papers
I was trying to put together a table that summarizes performance of motors used in FIRST (actually this was a while ago that I was trying to do this) and I found some questionable data. Some of the white papers provided by FIRST are pretty sloppy and some data even seems to be in conflict (I found implicitly that gear boxs efficiencies were greater than 100 percent for instance). If you haven't seen them for yourself already, you can get them from the FIRST website. The best example is probably the sheet on the chiaphua. It's just a poorly scanned drawing with a small (albeit decent) data table at the bottom. Am I crazy or does anyone else not trust the FIRST white papers?
Frag Out!
Rules, White Papers, UFH, etc. Brandon Martus Announcements 7 29-04-2004 19:46
White Papers Brandon Martus Announcements 1 28-01-2004 02:33
new scoring programs in white papers archiver 2001 4 23-06-2002 23:21
New White Papers & CDI Stats archiver 2000 0 23-06-2002 22:17
new white papers area Brandon Martus Announcements 0 09-10-2001 01:32
