so i want to put this code i got from the website
http://www.rec.ri.cmu.edu/education/...tent/index.htm specifically the IR Reflective Sensor Program for line tracking now in which file would i put thise code into? although the instructiosn say to put this code into user_routines.c, i thought you put autonomous code programming in user_routines_fast.c? can anyone shed some light? thanks in advance -noob at programming this is the code for line tracking Code:
void Default_Routine(void)/* BEGIN Default_Routine(); */
if(rc_dig_in06 == 0) /* if dark is seen */
pwm01=pwm03=127; /* turn left motors off */
pwm02=pwm04=96; /* turn right motors forward slowly */
else
pwm01=pwm03=159; /* turn left motors forward slowly */
pwm02=pwm04=127; /* turn right motors off */
printf("%d\n", rc_dig_in06); /* print light sensor readings */
} /* END Default_Routine(); */
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| Competition Scouting | pauluffel | Scouting | 31 | 09-01-2003 00:34 |
| Robot Scouting Database | archiver | 2001 | 10 | 24-06-2002 03:00 |
| Limiting PWM in pbasic | archiver | 2001 | 4 | 24-06-2002 00:38 |
