Go to Post We love both AndyMark and Vex for everything they do. The work these folks put into their products is amazing. - marshall [more]
Unread 17-02-2004, 09:45
MathewSmith's Avatar
MathewSmith MathewSmith is offline
The Guy
#1352 (Huskies Robotics)
Team Role: Webmaster
MathewSmith is an unknown quantity at this point
Send a message via ICQ to MathewSmith Send a message via MSN to MathewSmith
Will plexi-glass work?
so anyway, my team gets this great idea to make our robot's frame completely out of plexiglass. With only little metal brackets. I do not think this will work. We are an am. team, and we have nothing done. We have a few small pieces of plexiglass and a few metal brackets. we have no wiring done, no drivetrain. A flawed design that basically will only move. Sooo.....my question is.....Can we basically bend over and kiss our chances of even getting this done goodbye? Any help would be appreciated! thanks
Mathew Smith
team 1352
Unread 17-02-2004, 09:48
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Will plexi-glass work?
plexi glass is heavy!! not only that, but in the competetion (guessing you've never been to one) there is ALOT of pushing a shoving and ramming into each other. If there was no support behind the plexi (like studs in a wall) it would most likely break. I dont know about you, but i wouldnt want to have to fix plexi in the pits. If you are really looking for an easy way out, try getting some reliable wood, or just using the frame they give.
Unread 17-02-2004, 10:20
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Mathew Smith
team 1352
This is not supposed to be mean, but, you have NO chance of surviving a match with plexiglass. It will crack and break and splinter into a million pieces when another robot just barely nudges it... Our team learned this the first match in 2001 @ NYC. Hence why we have lots of lexan on reserve now. Attached is a pic of the shattering (the other robot barely nudged us on the side)...
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 17-02-2004, 10:39
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
Rookie Year: 2000
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
I'll throw this link in here so this thread doesn't turn out to be bad.
Critical and picky - here I go again
Even though i've not had much experience using Plexi-glass in robot operations, I've played with it enough to know that it will shatter and crack fairly easily. I also seem to remember a lot of threads in the past asking this exact same question, "Should we use plexi-glass or lexan" and the majority of the time most responses went, "Use lexan" for one reason or another.
Also, one thing i saw was people confusing the terms lexan(polycarbonate) and plexi-glass(acrylic). I just don't want this thread to turn into a "Let's argue about what its called thread".
This is not the end of the world for your robot. With the right support I think it will be just fine, but that's just my opinion.
Unread 17-02-2004, 10:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Plexiglass is a tough thing to use for robot body. It does shatter and easily cracks when you drill into it. Lexan works better and is less prone to damage but weighs a ton, heavier than aluminum. No you are not out of the competition at this point. Just think about a little modification. Use some aluminum extrusion to frame out the same dimensions you already have and start bolting it together. Move things bit by bit over to the new frame and voila! a robot is born. If you can't get it done before ship, cut as much as you can now and ship all the parts in the container with the robot. You will have lot's of work at your first regional but you can get it done. Ask for help from other teams, they are required to help if they can. I know that one team at Great Lakes last year, came with a box of parts and built their robot at the regional. "Never give up, never surrender!!"
Al
WB9UVJ
www.wildstang.org
________________________
Unread 17-02-2004, 10:49
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Mathew - are you sure it's plexiglas and not polycarbonate?
I'm sure if they broke any pieces drilling them it probably is polycarbonate. Those materials are a pain in the but to use.
Actually they are trade-names which is why it gets so confusing. The trade names for polycarbonate are: Lexan, Hyzod, and Tuffak. The trade names for acrylic well according to my book there is only one trade name. It is plexi-glass. Go figure. Also I have heard bad stories about using loctite on plastic materials. I heard it actually weakens the materials. Anyone care to find out if this is true?
*hint* Want to see something cool. Take two polarizing filters and stack them one on top of the other. Turn them until you can't see any light coming out. Then point them at a opaque material like lexan. You would be able to see any of the stresses put on the material*end of hint*
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 17-02-2004, 10:54
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
thsi late in the season I recommed you use 3/8" plywood for the base and the 2x4 alum pieces that FIRST gave your for the sides.
we built a pratice robot like this in november with parts left over from last year. It only took us 3 one hour meetings, at the highschool, to put it together and get it running
Im certain you could do the same in one weekend.
Unread 17-02-2004, 11:56
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Sorry to hear about your problems, but don't throw in the towel yet. It's easy to get overwhelmed, especially in your rookie year, with trying to do too much and seeing alot of things fail. You still have over a week left - see what you can do positively. Ken's idea about plywood and kit parts is a good start - get something driving so you can get some practice. A moving robot is an asset in any match - you can certainly block your opponent's corral and you can push balls even if one at a time. Use the default code - go back to square one and take smaller steps.
BTW - when you get to the competition I think you'll be surprised at how supportive other teams are. No-one will look down on you if your robot is dead, in fact they'll pitch in and try to help you get it started. You will enjoy this event regardless of how you robot performs.
Our rookie robot was named "Kenny" because it got killed every match. But we learned alot and moved on.
And don't use plexiglass/acrylic. Use Lexan/polycarbonate.
Close enough to taste it, too far to reach it
Unread 17-02-2004, 12:35
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
if you go with lexan instead of plexiglass ask for polycarbonate - same stuff much cheaper.....gl
Unread 17-02-2004, 13:05
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
Rookie Year: 1999
caffel is an unknown quantity at this point
There is only one plastic strong and tough enough. LEXAN.
All, that is All of the other and cheaper choi ces will crack and let you down. I can tell you this after 4 years of experience.
Charlie Affel,
Mentor 423
Unread 17-02-2004, 13:12
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
any chance of using lexa or plexiglass for a base is nto good. I am guess you are a rookie team. We use lexan to protect the compenents of our robot and for skins. Lexan is strong but not made to be a base. I would not quit yet but i would suggest go get some wood like mentioned about and just build it out of wood. Especially with a game that i think is gonna involve alot of contact between robots like last year youa re gonna need somethign that holds up
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 17-02-2004, 13:31
Scott England Scott England is offline
FRC #0118 (The Robonauts)
Rookie Year: 1997
Scott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to all
Didn't plexiglass(acrylic) used to be illegal on FIRST robots since it is so brittle? I know some acrylic got mixed in with our excess stock of polycarbonate, found out the hard way when it shattered while trying to be bent. Eitherway, polycarbonate frames have been done before. In 2001 we had a robot with no structural metal
Browsing the gallery, it looks like team 49 also did a robot made primarily out of lexan
So yes its possible, given your time crunch though, wood might be easier to get and to work with. Just get a drive train that runs first and go from there, there's still plenty of time left. Good luck,
~Scott
122 --> 401 --> 118
"The Earth is a very small stage in a vast cosmic arena. Think of the rivers of blood spilled by all those generals and emperors, so that, in glory and triumph, they could become the momentary masters of a fraction of a dot. Think of the endless cruelties visited by the inhabitants of one corner of this pixel on the scarcely distinguishable inhabitants of some other corner, how frequent their misunderstandings, how eager they are to kill one another, how fervent their hatreds. Our posturings, our imagined self-importance, the delusion that we have some privileged position in the Universe .... In our obscurity, in all this vastness, there is no hint that help will come from elsewhere to save us from ourselves. "
Carl Sagan
Unread 17-02-2004, 13:40
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I agree, if you absolutely must use a plastic, use lexan. It is more durable, and while it does splinter and shatter, it is less likely to do besides plexiglass. If you use this, you have to support it, using plexiglass or lexan will no support is a sure way to have a base be totally demolished. Supporting the base with aluminum extursion at stress points (if you can, ask an engineer to evaluate your design and offer advice on where to support it) is a very good idea.
Now Ken is also right. There is absolutely nothing wrong with using plywood as a base. In fact, one team that comes to mind that uses a wood base every year and is one of the well known teams in FIRST is Team 173 Rage. Every year they use a wood frame (which I'm not mistaken is supported by aluminum brackets). It may splinter, but with the brackets, it's an easy fix. Just put a sheet of aluminum or steel over it, bolt it on, and you're ready to go. I bring up Rage, because they are one of the well known teams that uses a wood base, and have so for years.
And yes, if you turn up at your regional with your robot unfinished, it's guarenteed other teams will come over to help you. No team is going to look down upon you, in fact most teams will do everything in their power to make sure your robot works and is able to compete. That's the great thing about FIRST, everyone is willing to help each other to make sure the competition is as good as it can be and everyone has a fighting chance.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 17-02-2004, 13:48
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
I don't know how physical this years matches will be but last year we shattered the side of a lexan robot in our first practice match (they ran into us). I still have a piece of it.
I would use wood and the aluminum for the kit. You can definitely get something driving and it will cut down on the repairs you will have to do at competition. You can compete if you can make something that can drive every match.
  #15   Spotlight this post!
Unread 17-02-2004, 13:52
Adam Y.'s Avatar
Adam Y.
no team (?????)
I disagree there are few other plastics that are better suited for a frame than lexan. Polyethylene is probably one of the better plastics to use for frame materials. It is easy to machine and very durable. The names to look for are HDPE (same stuff used in the fields) and UHMW. My best guess is that the gearbox and mounts are some form of polyethylene.
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
